Headlight electrical issue
Old Oct 31, 2011 | 11:52 PM
dlyter09's Avatar
dlyter09
Default Headlight electrical issue
Ok i did some searching but havent found what i was looking for. I went for a drive tonight and the trucks headlights will cut out when I tilt my wheel down. The fog lights will sometimes be the only ones on and sometimes they wont stay on. With the wheel the whole way up everything works fine. I didnt see any pinched wires anywhere so could it be a bad ground somewhere or a switch?
Old Nov 1, 2011 | 04:03 AM
peshewa's Avatar
peshewa
That could be a faulty ground, but I would get the battery & alternator tested too. Low voltage can cause that stuff to go wonky in order to keep power to the plugs for basic operation. I would check all the major connections at the pos/neg cables at both ends because that can cause all this too. Baring that, I would say it is time to start tracing wires for shorts in the column. If it comes to that & you are not really into wiring, I would say go to an auto electric specialist for definitive answers. Let us know what you find!
Old Nov 1, 2011 | 09:57 AM
Pull the covers off of the steering column, and have a close look at all the wires there. Move the column up and down with the covers off, might just be pulling some wires loose as it moves.
Old Nov 1, 2011 | 11:24 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I gotta say....what a crap thing to happen while driving in the dark...on Halloween? LOL
I'd like to know how this works out given we got same year rigs.
Old Nov 1, 2011 | 11:55 AM
dlyter09's Avatar
dlyter09
Yea it was a little weird. I was going down the road and went to adjust my wheel and BAM no lights.. I didnt seem to mind as much as the old lady did but o well.. Im gonna head out now and see what i can find. The battery terminals are brand new. Did them when it was gettin the transfer case changed along with a full tune up.
Old Nov 1, 2011 | 12:42 PM
grox's Avatar
grox
You should start checking the continuity between all the terminals on the switches, grounds, power, headlight relays, etc. You'll need a manual with electrical diagrams and an ohmmeter and some patience. Test everything with the wheel in the position causing the problem.
Edit: You'll want to disconnect the battery and have the headlight switch in the "on" position.
Edit 2: Testing the relays will require driving power to their appropriate terminals then checking continuity to see if they are functioning properly (so I would check those last)
Old Nov 1, 2011 | 02:06 PM
dlyter09's Avatar
dlyter09
Well I got it all figured out. I hate doing anything electrical but this was pretty easy. First i pulled all the covers off for the column and and removed all the electrical tape to check the wires. Didnt find anything there so I moved onto the plugs. Narrowed it down to the plug behind the highbeam/wiper/turn signal arm. Pulled that plug and found this.
I pulled the connector out of the plug to be able to have some room to work.
Connector out.
I put the wire back into the connector and put a little bit of solder on to help keep it in then put some electrical tape around the connection for some extra insurance.
With all that done I put the connector back into the plug and with the tape on there I used a small set of needle nose pliers and shoved it into the plug so it stayed nice and tight. Put everything back together and its all fixed now. I did discover that I had a 5 amp mini fuse blown for my illumination but thats not as much of a big deal as the headlights not working.
Hope this helps for anyone who could have the same kind of issue as I did.
Old Nov 1, 2011 | 09:59 PM
peshewa's Avatar
peshewa
Thanks for sharing the fix man, glad it was a cheap one!
Old Nov 1, 2011 | 10:47 PM
Awesome! Glad it was an easy one.
Old Nov 1, 2011 | 11:07 PM
dlyter09's Avatar
dlyter09
Yea it was simple besides needing 3 hands to put all the column pieces back together
