Rear axle upgrade
Old Nov 4, 2011 | 01:04 AM
peshewa's Avatar
peshewa
Default Rear axle upgrade
I saw a thread here about a week ago with detailed advice on what axle to choose as an upgrade, but now I cant find it. I am saving up to go to a coil over double triangulated 4 link, but I wont do it to the stock axle. Any advice?
Old Nov 4, 2011 | 01:47 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
D60.
Shun!
Old Nov 4, 2011 | 02:42 AM
biggreen2500's Avatar
biggreen2500
i've broken 4 of my dana 60s in my 2500 i'd look for a d70 or a d80
Old Nov 4, 2011 | 09:08 AM
Even the one ton trucks had D60's in the front...... you won't find anything meaner that will be as easy of an installation.
How do you break front ends so often?
Old Nov 4, 2011 | 12:34 PM
99dodge318's Avatar
99dodge318
I think big green is talking about his rear axle.
Peshewa which axle are you talking about?
The most popular swap is dana 60's front and rear. Also I would look for the axles with 4.11 gears theres few of them, so you might have to search everywhere.
Also I think 2000+ rams came with dual piston calipers in the front, and some had disc brakes in the rear.
Others will chime in and correct me
Old Nov 5, 2011 | 01:00 AM
peshewa's Avatar
peshewa
Well guys, I have rear drums & my 2nd gen is a 2wd. My goal here is to simply have modern suspension. I have driven older chevy trucks that had the double triangulated rear with coil overs and some sand bags in the back, and even though they were not lowered, they were able to corner much more like a modern car. That is what I am after. I know how to make the 4 link set up I want without a kit, I just need more info on what rear end options are going to be good for me. I know in my area, a lot of folks like the rear axle from the exploders with the 9 inch in the back. Many of those have disc brakes already & are known to be tough, but I have this aversion to fords.
Old Nov 5, 2011 | 03:42 AM
biggreen2500
yep i broke the rear ends... yeah my dana 60 front is amazing i'd swap there into it but the rear ends i've had major problems with. even the shop i used doesn't know why i keep break a dana 60
my 2001 dodge ram 2500 has 4 wheel disc brakes and yes i got dual piston calipers
Old Nov 5, 2011 | 11:52 AM
Wombat Ranger's Avatar
Wombat Ranger
How are you breaking Dana 60's?
The shop doesn't know because nobody breaks Dana 60's... they are a very strong axle, and are the bread and butter of the 4x4 world. if your having so much issues with them, i would 1) look into who's putting them together and what they are doing wrong, or 2) get yourself a set of 35 spline yukon shafts. You won't (should't) break those...
Old Nov 5, 2011 | 12:06 PM
merc225hp's Avatar
merc225hp
Just what is breaking in the Dana 60?
