Jack Points
Old Nov 8, 2011 | 07:38 PM
DodgeSporter's Avatar
DodgeSporter
Originally Posted by EFS463
i got a 4x4 so that wont work
I think he ment a 4x4 piece of wood not a 4x4 truck
Old Nov 9, 2011 | 08:49 AM
Sheriff420's Avatar
Sheriff420
2x6 board on the floor jack and put it right on the bottom of the u-bolts in the rear (the board is so I don't hose the threads on the u-bolts).
If I need to put the rear on jack stands I put the jack directly on the shock mounts and don't worry about a board. Then I put the stands in between the u-bolts.
4x4 or 2x6 board on the jack and put it right on the end of the lower control arm for the the front.
Old Nov 10, 2011 | 09:01 AM
EFS463's Avatar
EFS463
To clear things up I meant that I have a 4WD truck. For the rear, is it SAFE to use the shock mounts? I know I have hear about jacking over the u-bolts but I was gonna use the shock mounts. And in the front I really don't know where to put the jack because unless you jack on teh frame idk of anywhere thats safe. I like workin on my 2wd ford better lol
Old Nov 10, 2011 | 12:24 PM
merc225hp's Avatar
merc225hp
For the rear I put the jack to the inside of the u bolts and jack on the axle tube then put the jack stand under the u bolts. Just use the axle tube for you jack spots. This is not hard. See post #9
If you use a floor jack put the wood on top of the jacking pad(not my fav for jacking up a lifted truck), for a bottle jack put the wood under it(perfered).
Not the best pic but it will give you an idea on the front.
Old Nov 10, 2011 | 01:10 PM
You did fix your axle seals as well there, right?
Old Nov 10, 2011 | 01:18 PM
merc225hp's Avatar
merc225hp
Nope, I had been driving the truck without that axle in and just a rag stuffed in the hole and it did leak. I changed the seals about 4 years ago when I put in the DL. It's drip free You just want me to work on it some more right.
Old Nov 10, 2011 | 01:23 PM
Well, you WERE Running out of things to do around there.........
Old Nov 10, 2011 | 01:29 PM
merc225hp's Avatar
merc225hp
LOL Sadly "yes" I am going through withdrawal not working on it for two days. Oh thats bad
Old Nov 10, 2011 | 05:13 PM
chadwall's Avatar
chadwall
Bottom of pumpkin, then put stands on axle close to wheels. Stands have a half moon shape perfect for the axle tube..
Old Nov 10, 2011 | 05:17 PM
stewie01's Avatar
stewie01
If the working on it is stuff you want to do, ie; improvements, modifications, etc.. then it's ok to be in withdrawal. If working on it means replacing and fixing everything that breaks, withdrawal might be a concern
