1998 Dodge Ram Threw a Rod
Old Nov 7, 2011 | 09:03 PM
watsupdud109's Avatar
watsupdud109
Default 1998 Dodge Ram Threw a Rod
I was driving down the road, and my transmission decided to stop shifting and the truck revved to 6k before it shifted, while later down the road the engine started to get a knock to it, and drove it a little further and i heard the rod go through and the engine die, shot the rod through the oil pan.. have had this truck for 2 weeks and a couple hundred miles.. Anyways its a v8 351 automatic, 4x4, and I'm guessing its gonna need a new transmission too, so how much would it be to put a new motor and transmission in.. planning on finding them both used and probably putting them in mself.. how much work will it be?
Old Nov 7, 2011 | 09:13 PM
J415's Avatar
J415
How'd you get a 351 in there? You sure it isn't a318 or 360?
Old Nov 7, 2011 | 09:19 PM
watsupdud109
Sorry my bad.. I'm tired haha and was wishing i had my ford back.. yeah 360 although i was told a ford 351 would be the easiest thing to match up in there
Old Nov 7, 2011 | 09:21 PM
Hahns5.2's Avatar
Hahns5.2
Rev limiter is 5200, no way it made it to 6k.
Old Nov 7, 2011 | 09:22 PM
watsupdud109
Watched it bounce of 6k.. Like I said.. had the truck 2 weeks couldn't tell you if it has its rev limiter still or not
Old Nov 7, 2011 | 09:31 PM
kejobe's Avatar
kejobe
I've seen motors and trannys sell for $200 all the way up to $800 each. It all depends on what is available in your area and how much you want to spend.
Old Nov 7, 2011 | 09:55 PM
gdstock's Avatar
gdstock
A Ford 351 is not the easiest thing to put in. PCM and all other electrical instrumentation will not work. Motor mounts will not work. Wiring harness will not work. Putting the same thing back in there would be the easiest and most prudent thing to do, with whatever mods, upgrades, and hardening you can afford to do.
Old Nov 7, 2011 | 09:59 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You buy this from a dealer or private? 2 weeks old this happens and no consideration of recourse? ouch man
+1 to kejobe and gdstock.
Old Nov 7, 2011 | 10:42 PM
watsupdud109
Bought it private.. traded my 91 cummins for it.. Talked to him after it happened.. told me the motor was fine while he was driving it and the transmission got rebuilt 40k miles ago.. It sucks but what else can i do..
Old Nov 7, 2011 | 11:11 PM
Unless you can prove he knew the engine was on its way out, you are screwed. First thing you need to do though, is find out how much a used engine is gonna run. If you can put it in yourself, you can save some serious coin. (probably around 600-800 bucks JUST for installation.....) Once you have a good engine in there, then, start trouble shooting the trans. If it was rebuilt 40K ago..... shouldn't be anything really major. (or, he is lying thru his teeth.....)
