did the plenum reapir now i have a CEL on? i need help
Old Nov 9, 2011 | 05:21 PM
biggreen2500's Avatar
biggreen2500
Originally Posted by zman17
Now look at the link I gave you.
already did there boss
P0112 Intake Air Temp Sens Voltage Low
P1687 No Cluster BUS Message
i'm not sure where i'd start to look for how to correct these 2 codes
Old Nov 9, 2011 | 05:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Calm down there boss, LOL We are posting at the same time.
First thing is check the sensor plug, you may have knocked it off of broke it. And trace the wire back to the PCM.
Old Nov 9, 2011 | 05:25 PM
biggreen2500
whast the sensor plug? is it the one thats right next to the heater core hose going into the intake next to the t-state housing?
Old Nov 9, 2011 | 05:29 PM
ECT is next to thermostat housing. Make sure it is still plugged in good. There is a lotta stuff around it, so, prolly easy to miss when putting things back together.
Old Nov 9, 2011 | 05:30 PM
zman17's Avatar
zman17
No, it's the one on the passenger side of intake behind the alternator just above the fuel rail.
biggreen2500
okay i'm gona go out side right now and look i'll be back in a sec
merc225hp's Avatar
merc225hp
Air temp sensor is in the side of the intake, did you remove it before you modded you intake? It might be pluged with bits of aluminum from your cutting of the runners. Also check for pinched wires running down the side of the intake. The ECT is right were HeyYou said it is, two differant parts.
Old Nov 9, 2011 | 05:31 PM
I need to quit posting when I am tired....... IAT, not ECT......
Old Nov 9, 2011 | 05:37 PM
zman17's Avatar
zman17
Someone needs to lay off the pain killers,
Old Nov 9, 2011 | 05:38 PM
biggreen2500
okay i checked it.. its was plugged in all the way i took it out an dre pluged it in to see if it made a differnce it did not...
any other ideas
