Difference between 5.2 and 5.9 Radiator
Old 11-10-2011 | 01:43 PM
dtrumbower's Avatar
dtrumbower
Default Difference between 5.2 and 5.9 Radiator
Can a radiator for a 5.9L work for a 5.2L? It sounds like the oil lines might have a different connections.
Thanks
Dwight
Old 11-10-2011 | 01:48 PM
Archion's Avatar
Archion
94-01 3.9,5.2,5.9 all take the same aftermarket part # (1552) in most cases. A couple of manufactures seperate the 5.9 as an aftermarket part# 2291 (98-01)and has a larger internal cooler. The difference may also be in that one has an auxillary trans cooler. The fitings/lines/cooler can be swapped in most cases, some aftermarket units can be harder than others due to varying manufacturing standards
Old 11-10-2011 | 01:51 PM
dtrumbower's Avatar
dtrumbower
Thanks for the reply. It's a 1999 ram 1500. I've located a used rad from 5.9L, OEM. Sounds it should work then.
Appreciate the help.
Old 11-10-2011 | 01:55 PM
Archion's Avatar
Archion
Should in most cases, but always match it up completely before you install and fill. Also if that is a used automatic unit, flush/clean the cooler as few times. it's a good possibility that the source truck had a bad trans with these trucks.
Old 11-10-2011 | 01:57 PM
dtrumbower's Avatar
dtrumbower
What is the best way to flush the cooler? That's a good point.
Thanks
Old 11-10-2011 | 02:22 PM
Archion's Avatar
Archion
You can get cooler flush from most decent parts stores or supply house, like napa, carquest or if you have a Dacco Detroit or ATC in your area.
Old 11-10-2011 | 02:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Wouldn't brakleen and compressed air work as well?
Old 11-10-2011 | 03:14 PM
Archion's Avatar
Archion
It can in most cases, but the trans cooler flush is actually a little stronger chemically and with the track record of these transmissions, I like to get as strong a product as I can.
Old 11-10-2011 | 03:18 PM
zman17's Avatar
zman17
Ok, thanks for the info.
Old 11-10-2011 | 03:21 PM
Archion's Avatar
Archion
NP, What works really well, is if you have access to the evaporative type A/C flush and a flush gun...
Quick Reply: Difference between 5.2 and 5.9 Radiator
