Transmission Went Out Today!
Old Nov 14, 2011 | 04:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Dycrow27
Alright so i decided i was gonna go and replace the governor pressure solenoid and sensor. I know that you cant gurantee my problems being fixed but from what i say does it seem like this is the cause. My transmission shifts strong and doesn't slip but just has trouble of knowing when to switch and running 3 grand before it shifts is not good for my wallet or motor.
Chances are pretty good that replacing the Gov solenoid and pressure switch will cure the problem. Remove the Gov body and clean it also. And get one of these if you can .
Old Nov 14, 2011 | 08:10 PM
Augiedoggy's Avatar
Augiedoggy
Got that exact one on order...$52.00 with expedited shipping from ebay.... and I'm rebuilding the one I have in the truck now for a backup since its only got 9,000 miles on it.... these things are really unreliable it seems from all the threads I read today..
Old Nov 14, 2011 | 08:44 PM
J415's Avatar
J415
Can you post an ebay link? I can't seem to find it.
Old Nov 15, 2011 | 01:44 AM
peshewa's Avatar
peshewa
ebay item# 330602330540
Old Nov 15, 2011 | 07:31 AM
J415's Avatar
J415
Thanks!
Old Nov 15, 2011 | 08:12 AM
Augiedoggy's Avatar
Augiedoggy
They have a pretty good selection of various new name brand 02 sensors for $20 shipped as well on ebay....you just have to wire the connector onto the end.
Old Nov 15, 2011 | 05:23 PM
Augiedoggy's Avatar
Augiedoggy
well I added more fluid since I was half a quart low and drove around the block...it shifts okay till I get to the end of the street then wont shift out first...I got three errors
P0713 temp sensor too high
p0753 trans shift soleniod
p1763 gov pressure sensor too high..
Old Nov 15, 2011 | 10:31 PM
Dycrow27's Avatar
Dycrow27
I ordered the heavy duty BW governor pressure solenoid and the sensor for my truck will be here Friday and ill be replacing drive-shaft, u joint, sensor, and solenoid Saturday I'll let you guys know what the outcome is. All the parts cost me about $150 F.Y.I. Thanks for all the help on this subject everyone
Old Nov 15, 2011 | 10:46 PM
Augiedoggy's Avatar
Augiedoggy
I pulled mine out today and refurbished the soleniod (Via dodgeforum thread on the procedure) because the replacement I ordered might not show until the day of my trip.... Come to find out two of those errors above point to the governor sensor and not the soleniod so its still doing the same thing... figures..I hope napa has one locally tomorrow..
FYI you will loose about 5.5 quarts of ATF+4 fluid after dropping the pan so its a good idea to replace that with fresh stuff.
Old Nov 15, 2011 | 10:48 PM
gdstock's Avatar
gdstock
And installing a drain plug will make life easier in the future.
