Factory LSD
Old Nov 11, 2011 | 11:55 PM
DodgeTheDadRamTheDaughter's Avatar
Default Factory LSD
What year did they start making rear LSD an option for the trucks? Im wanting to pick up a used unit when i install my gears and i noticed when i look for install kits it breaks from up to 2000, and lists from 2001 on. So i was thinking maybe 2001 was when it became an option since the install kit suggests that? If so if i were to get an LSD unit out of the 01-02 should it swap in just fine with using the 01-on gear install kit?
Old Nov 12, 2011 | 12:26 AM
biggreen2500's Avatar
biggreen2500
my 2oo1 2500 has a Limited Slip Differential
not sure about 1500s tho
Old Nov 12, 2011 | 03:41 AM
97tn4x4's Avatar
97tn4x4
Since 94. I don't know why there is a break though.
Old Nov 12, 2011 | 12:41 PM
Do you guys think the factory LSD is a worthwhile swap when im doing the gears or should i just save my money and leave the open differential in. Also, is the dana trac-loc the stock LSD unit? I fount a brand new one for $286.
Old Nov 12, 2011 | 12:58 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
If you are replacing the factory LSD, then the best replacement (that I've come across) is an Auburn. Check them out. Much more longevity in them vs. the factory. This is just based on my own findings of other users.
Old Nov 12, 2011 | 03:31 PM
I currently have an open diff and was considering swapping in a factory diff
Old Nov 12, 2011 | 03:42 PM
If you can find one dirt cheap, sure, it's better than the open differential. If you are spending more than a couple hundred on it though, there are much better alternatives, ranging from a lunchbox locker, that just replaces the spiders in your open diff, to "real" lockers. Have you sourced any parts yet??
stewie01's Avatar
stewie01
Leave the open diff, save up a few hundred and buy a Detroit Locker or whatever brand you like. The Detroit's run just over $600 from Summit Racing, high, but it's about that much elsewhere too.
Old Nov 12, 2011 | 09:41 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You inquired about putting in a factory LSD, right? Are you looking at the factory LSD (which is Open) purely b/c of price?
What type of driving are you mostly targeting? If you are primarily road, then a LSD is more appropriate.
If you are looking at more full time locking, then yes consider the input from HeyYou and Stewie. However, how the thread got to actual "lockers" is over my head.
I was suggesting a better LSD, the Auburn, since you were asking about a LSD. The factory LSD is notorious for short life due to the clips breaking.
Good luck
Old Nov 13, 2011 | 02:16 AM
The trucks came with open differentials or Limited Slip. I have an open differential, i was inquiring about putting in a limited slip diff factory unit, out of truck that came from the factory with the LSD. This is my daily driver/pavement pounder/tow vehicle. With snowy and ice conditions in michigan i'm thinking a lunch box or true locker would not be the best choice. I was just wondering if a limited slip unit factory model would be worth while for $286 new or if i could find a cheap used one. I can see where the gear unit limited slips like the Auburn or Detroit would be solid units, but they are double the price. So the factory units with the clutch packs wear out that quickly, that i should just look past them?
