What other 5.2s fit?
Old Nov 12, 2011 | 01:40 PM
mcweaver's Avatar
mcweaver
Default What other 5.2s fit?
Will all 5.2 engines fit in my 98 1500 4x4? Mine has just over 200,000 miles and I'd like to go ahead and find another one and slowly start rebuilding one. Will a 5.2 out of a van, cherokee, durango and whatever else fit?
Old Nov 12, 2011 | 01:43 PM
any 5.2 92? and up will work. (so long as it is a magnum engine.) Just make sure you use sensors and such for the correct year truck.
Old Nov 12, 2011 | 02:13 PM
mcweaver's Avatar
mcweaver
Thanks! I'm thinking I can pick one up for just under $500 and put it on a stand in my garage and should be a nice project for me to do with my sons!
Old Nov 12, 2011 | 02:16 PM
That sounds like a good plan. Teaching your kids some of this stuff is ALWAYS a good thing.
Old Nov 12, 2011 | 02:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Take the intake off your current motor, fix the plenum and swap it with the intake on the newer motor.
Old Nov 12, 2011 | 03:17 PM
mcweaver's Avatar
mcweaver
how do I tell if its a magnum or not?
Old Nov 12, 2011 | 03:45 PM
The year it was made. 93 and up are magnum engines. Should be casting numbers on the block, you can decode those to tell you what year.
Old Nov 12, 2011 | 05:21 PM
dhvaughan's Avatar
dhvaughan
for the magnum - i think the intake shape/look is also distinctive - but - the 5.9 and 5.2 magnums also look alike, so you probably should know the block numbers. i don't know them. you don't want to accidently get a 5.9, or you have to change more stuff including pcm tuning.
Old Nov 12, 2011 | 05:59 PM
Here ya go. Everything you need to know to make sure you get the right engine.
Old Nov 12, 2011 | 09:20 PM
mcweaver's Avatar
mcweaver
thanks guys!
