ABS light
Old Nov 16, 2011 | 04:53 PM
shorty24v's Avatar
shorty24v
Default ABS light
Well, I was replacing my hub on the front right and wasn't able to finish it myself so I had the truck towed to my uncles work and he finished it today. He just called and said when he finished, and when he was taking it for a test drive the ABS light came on and the speedo wasn't working, any ideas?
Old Nov 16, 2011 | 05:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Bring it back to your uncle and ask him what he screwed up.
Old Nov 16, 2011 | 06:30 PM
shorty24v's Avatar
shorty24v
Well, it's still at his work. He was just on the test drive when he saw it. So he said he'll look tomorrow, and I was just trying to get leads so he won't have to spend too much time.
Old Nov 16, 2011 | 07:17 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Couple threads stumbled across, but have no idea if they are helpful. Just saw the thread titles...
https://dodgeforum.com/forum/2nd-gen...t-showing.html
https://dodgeforum.com/forum/2nd-gen...t-come-on.html
If they help, then awesome. If not.... *shrug*
Old Nov 17, 2011 | 07:14 PM
shorty24v's Avatar
shorty24v
Thanks. the second link helped it was the, it was the sensor. But, it went because of the lift and putting the truck on a lift, it pulled the wires right out of the sensor itself. So replaced that and I'm all good.
Old Nov 17, 2011 | 07:25 PM
stewie01's Avatar
stewie01
Did that fix your speedo too?
Old Nov 17, 2011 | 08:16 PM
shorty24v's Avatar
shorty24v
yep and he used his scanner and changed the tire size to 275/75 16 instead of the stock 245/75 16. So it's more accurate, mire tires are 285/75 16 but 275 is the highest his scanner would let him go.
Old Nov 17, 2011 | 08:21 PM
stewie01's Avatar
stewie01
Did you ever get your stripped lug problem resolved?
Old Nov 17, 2011 | 08:46 PM
shorty24v's Avatar
shorty24v
Actually yes, I was ended up replacing the hub itself, while taking the wheel off another stud just broke off, so I was down to 2 good ones. So I ended up just replacing the hub, which putting it on the lift caused this problem.
I went back in the forum today to find the thread I started about that problem and when it was so far back since the last update, I thought nevermind no one probably remembers. So thanks for asking.
