electrical power inverter?
im not sure where to put this so im placing it under the type of truck i drive.
I plan to install a 5000-8000W power inverter for a 110V 40A air compressor i recently acquired. currently things are stock in my engine but i wounder what the best way to provide power to this would be? a second battery? what type of battery, deep cycle vs standard optima? will a second alternator be required?
i intend to upgrade to a 2500 at some point so perhaps i will chance upon the model with dual batteries.
the inverter would pull around 400A at 12V when the compressor is running.
any ideas, thoughts, concerns?
thanks
thanks
im looking into possibly rewiring the 110 to 220 but im not sure if its possible with this model. its built in 1967 but i got it for 15 bucks, its 25 gal and dual piston, maxes at 200psi. i had to run it at work as no outlet in our house can power it. that said a 5K power inverter is only a couple hundred where as a new compressor is more around 1700. im looking into perhaps taking an old lawn mower and rigging it to the compressor in place of the current motor. im just bouncing ideas around but the inverter would give me the most in dual purpose. i have a small 2KW inverter in the truck now but it cant run alot of what i would like.
my stereo pulls 416A at max load, however its rarely ever pulling that much, id guess it pulls around 200A average while im driving.
as opposed to buying a generator what would it take to rig up a pump on the serpentine belt of the engine? im on a budget so my goal is to make this all work for under 400 bucks max but im shooting for no more than 100. I built a 3KW power inverter out of old microwaves but it was unable to run the compressor and its currently a bit larger than i want.
yea, i was thinking of using a second deep cycle battery with an isolator, my current red top, and my stock alternator. the air compressor would come on once ever 30-45 min under basic usage and perhaps once every 10-15 min when im doing auto work. i heard a rumor that some old GM air conditioning pumps can be easily turned into a compressor, i may take a look into that.
Trending Topics
there is the RV2 Compressor that was used in according to rock auto.
CHRYSLER 300 (1961 - 1971)
CHRYSLER CORDOBA (1975 - 1979)
CHRYSLER IMPERIAL (1961 - 1975)
CHRYSLER LEBARON (1977 - 1978)
CHRYSLER NEW YORKER (1961 - 1979)
CHRYSLER NEWPORT (1966 - 1979)
DODGE 880 1963
DODGE A100 (1969 - 1970)
DODGE ASPEN (1976 - 1978)
DODGE B100 (1971 - 1980)
DODGE B200 (1971 - 1980)
DODGE B300 (1971 - 1980)
DODGE CHALLENGER (1970 - 1974)
DODGE CHARGER (1966 - 1978)
DODGE CORONET (1966 - 1976)
DODGE D100 PICKUP (1969 - 1979)
DODGE D150 PICKUP (1977 - 1980)
DODGE D200 PICKUP (1969 - 1980)
DODGE D300 PICKUP (1969 - 1980)
DODGE D400 PICKUP (1978 - 1980)
DODGE DART (1962 - 1976)
DODGE DIPLOMAT (1977 - 1978)
DODGE MAGNUM (1978 - 1979)
DODGE MONACO (1965 - 1978)
DODGE POLARA (1963 - 1973)
DODGE RAMCHARGER (1974 - 1980)
DODGE ROYAL MONACO (1975 - 1977)
DODGE W100 PICKUP (1969 - 1977)
DODGE W150 PICKUP (1977 - 1980)
DODGE W200 PICKUP (1969 - 1980)
DODGE W300 PICKUP (1969 - 1980)
PLYMOUTH BARRACUDA (1967 - 1974)
PLYMOUTH BARRACUDA GRAN COUPE (1970 - 1971)
PLYMOUTH BELVEDERE (1968 - 1970)
PLYMOUTH BELVEDERE SATELLITE (1968 - 1970)
PLYMOUTH DUSTER (1970 - 1976)
PLYMOUTH DUSTER 340 (1970 - 1973)
PLYMOUTH DUSTER 360 (1974 - 1975)
PLYMOUTH DUSTER CUSTOM 1975
PLYMOUTH FURY (1962 - 1978)
PLYMOUTH FURY CUSTOM (1971 - 1975)
PLYMOUTH FURY CUSTOM SUBURBAN (1968 - 1975)
PLYMOUTH FURY GRAN COUPE (1970 - 1972)
PLYMOUTH FURY GT 1970
PLYMOUTH FURY I (1968 - 1974)
PLYMOUTH FURY II (1965 - 1974)
PLYMOUTH FURY III (1965 - 1974)
PLYMOUTH FURY POLICE 1974
PLYMOUTH FURY S-23 1970
PLYMOUTH FURY SALON (1976 - 1978)
PLYMOUTH FURY SPORT (1966 - 1978)
PLYMOUTH FURY SPORT GT 1971
PLYMOUTH FURY SPORT SUBURBAN (1968 - 1978)
PLYMOUTH FURY SUBURBAN (1968 - 1978)
PLYMOUTH FURY VIP (1966 - 1969)
PLYMOUTH GRAN FURY (1972 - 1977)
PLYMOUTH GRAN FURY BROUGHAM (1975 - 1977)
PLYMOUTH GRAN FURY CUSTOM (1975 - 1976)
PLYMOUTH GRAN FURY CUSTOM SUBURBAN (1975 - 1976)
PLYMOUTH GRAN FURY SPORT SUBURBAN (1975 - 1977)
PLYMOUTH GRAN FURY SUBURBAN (1975 - 1977)
PLYMOUTH ROADRUNNER 1974
PLYMOUTH SATELLITE (1968 - 1974)
PLYMOUTH SATELLITE BROUGHAM 1971
PLYMOUTH SATELLITE CUSTOM (1971 - 1974)
PLYMOUTH SATELLITE REGENT (1971 - 1974)
PLYMOUTH SATELLITE SEBRING (1971 - 1974)
PLYMOUTH SATELLITE SEBRING PLUS (1971 - 1974)
PLYMOUTH SATELLITE SPORT 1970
PLYMOUTH SCAMP (1971 - 1976)
PLYMOUTH SCAMP SPECIAL 1976
PLYMOUTH TRAILDUSTER (1974 - 1980)
PLYMOUTH VALIANT (1962 - 1976)
PLYMOUTH VALIANT 100 (1968 - 1969)
PLYMOUTH VALIANT BROUGHAM (1974 - 1975)
PLYMOUTH VALIANT CUSTOM 1975
PLYMOUTH VALIANT SIGNET (1968 - 1969)
PLYMOUTH VOLARE (1976 - 1978)
PLYMOUTH VOLARE CUSTOM (1976 - 1977)
PLYMOUTH VOLARE PREMIER (1976 - 1977)
DODGE 880 1963
You'd require the king of all alternators to be able to power the electronics capable to run the compressor full tilt at 100% duty cycle unless you plan to draw off the battery which gets expensive quick. Inverting from 12V seems like an extremely expensive way to go for this kind of power level. In the end I highly doubt you'll be able to justify the cost once you realize what it's really going to take electrically.
If you have one of those PTO transmissions on there you could use one of those PTO driven generators and power a whole truckload of compressors. You could potentially even somehow chassis mount the generator and have some conveniently located outlets I would imagine.
