type of injectors??
Old Nov 27, 2011 | 08:07 PM
4085spd's Avatar
4085spd
http://www.youtube.com/user/rbanner100?blend=22&ob=5
Another BOSCH injector comparission where he raises the fuel pressure to 60psi and the injectors are not spraying any different or dribbling out fuel like you say they would. Whom ever told you this or where ever you read this is wrong. Flow matching injectors are a standard process when rebuilding them. You realy think an set of 8 injectors flow the same after 100k? Dont think so.
Old Nov 27, 2011 | 08:31 PM
Some types of injectors have issues going to higher than rated pressures, and tend to either get stuck open.... or, won't open. (disk type.)
Old Nov 27, 2011 | 08:48 PM
drewactual's Avatar
drewactual
Bosch are pretty good... Siemens is the best.. ford motor sports are pretty decent.. any of those three are pretty consistent at different pressures and from injector to injector.. .. get into cheap brands, like accel, for instance, and there is no telling what they will do... You'd only know if you hooked them up and tested them..
Don't know the p/n of mine off the top of my head, but they are the FMS gen iii 4 hole ev6 22# deals.. got them from fiveo.. had to alter tune because of them.. once I got them dialed in, I didn't see anything that made it worth while to do it again..
Old Nov 27, 2011 | 08:54 PM
merc225hp's Avatar
merc225hp
Why are Accel injectors considerd "cheap" I have a new set in my truck working just fine.
Old Nov 27, 2011 | 09:01 PM
drewactual's Avatar
drewactual
The metal body accels were a mess when doing flow tests and ratings.. ckeamma used to hang around a bit, he and capt are the ones that schooled me.. ck had some serious concerns about accel metal bodies.. I had a set, but never used them after what he said.. I sent them back and got the fms's.. they are cheaper MUCH cheaper than Siemens.. a set of gen iii Siemens can run upwards of $800... The accels can be had for $150.. I think I paid $300 or so for the fms's...
Who's to say what though? You could have a set of metal body accels and be just fine, if they were flow rated and calibrated together..
Old Nov 27, 2011 | 09:11 PM
merc225hp's Avatar
merc225hp
Thanks for the info. I don't have the box at hand but I do remember reading about a matched set and something about a new version? I will look into it more later. I was shocked to see three holes instead of four in the new injectors.
You guys get parts sooo much cheaper than us!
Old Nov 27, 2011 | 10:16 PM
4085spd's Avatar
4085spd
Dont know where you read that from but it is not true false statement. ALL BOSCH DESIGN 3 injectors are disc and do not hang open like the chevy multecs do as shown in the two videos post as proof. AND its not the disc but the actual coil within the injector that hangs up not the disc.
FYI FMS are ALL bosch which are the best anyone can get. If you dont have the actual part number of the injector you bought then how you know that there 22lb injectors? Taking or reading from the WWW doesnt mean there actually 22lb injector. In fact looking through my data FMS never made a EV6 22lb injector so id say there 24's thus lol running rich.
Old Nov 27, 2011 | 10:19 PM
FYI FMS are ALL bosch which are the best anyone can get. If you dont have the actual part number of the injector you bought then how you know that there 22lb injectors? Taking or reading from the WWW doesnt mean there actually 22lb injector. In fact looking through my data FMS never made a 22lb injector so id say there 24's thus lol running rich.
Design three? Oh, so that implies there was a design one, and two. Just because the CURRENT design doesn't suffer from the issue, that does NOT imply that the previous designs did not.
Old Nov 27, 2011 | 10:23 PM
4085spd's Avatar
4085spd
Believe anything that guy has to say is a joke within itself. Guy faked his own threads to sound cool. 5volt no starts stop immediately after he stopped posting. Seem to happen alot around these part.
Old Nov 27, 2011 | 10:27 PM
4085spd's Avatar
4085spd
That just show right there you have no experience with injectors.
Your best friend http://www.google.com/ read some more.
