vibration damper bolt
Old Nov 28, 2011 | 06:07 PM
plott hound's Avatar
plott hound
Default vibration damper bolt
quick question guys,got the truck all back together but forgot to torque the vibration damper bolt while the starter was off.its supposed to torque down to 130ftlbs,i got it as tight as possible with the torque wrench then bumped it twice with the impact gun.is there a way to hold damper and pulley from turning while i torque it properly?i hate the thoughts of taking the starter off again.laying under the truck for 3 hours on saturday was more then enough for me.
cheers.
Old Nov 28, 2011 | 07:10 PM
No. Don't hold the outside of the balancer. Hit it again with the impact, and just call it good.
Old Nov 28, 2011 | 07:18 PM
plott hound
Thumbs up
fair enough hey you.cheers man!
Old Nov 28, 2011 | 07:35 PM
gdstock's Avatar
gdstock
De[pends on impact wrench I would think. Some 1/2" drives may not be good enough. A 3/4" probably would. How solid is your impact?
Old Nov 28, 2011 | 08:52 PM
J415's Avatar
J415
Well, I know my Milwaukee impact wrench tops out at 130 foot pounds. Plott Hound, find out what your impact gun tops out at and then you'll know what's what.
Old Nov 28, 2011 | 09:09 PM
plott hound
impact gun is a good one,used it to remove the bolt.not sure what it tops out at,can figure that out tomorrow.
Old Nov 28, 2011 | 09:21 PM
BigBlue83's Avatar
BigBlue83
what would happen if it wasnt torqued right im sure the obvious is come back off but any other thoughts
Old Nov 28, 2011 | 09:26 PM
Magnum4406's Avatar
Magnum4406
I'm with HeyYou, Hit it with the impact and call it good. I have put a bunch on that way and never a problem.
Old Nov 28, 2011 | 09:33 PM
redheadhunter21's Avatar
redheadhunter21
impact it and call it good, thats what I did and havent had a problem, and I was using a craftsman impact gun
