will 16x7 stock rims fit 315/75/16s?
Old Nov 29, 2011 | 12:08 AM
cutthroatxxx's Avatar
cutthroatxxx
Default will 16x7 stock rims fit 315/75/16s?
On my 95 I have the stock 16x7 wheels is anybody running 315/75/16s Im getting tires anyday now&I was gonna get the 315s but Ive heard you cant run em.Has anybody?Actually I think the wheels are 16x7.5 not sure
Old Nov 29, 2011 | 12:33 AM
merc225hp's Avatar
merc225hp
Recomended rim width for that tire is 8.5" to 10" tire shops up here would not mount those tires on your stock rims.
Old Nov 29, 2011 | 01:00 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Why would you order tires prior to knowing beforehand about appropriate rim size?
c'mon...i had to do it!!
Old Nov 29, 2011 | 01:04 AM
cutthroatxxx
Why would you assume I orderd tires?I said Ill be getting tires anyday now...meaning Ill be going to buy em soon as I find out if they'll fit,hince the reason Im asking.
Old Nov 29, 2011 | 01:07 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Why would yoy assume I orderd tires?I said Ill be getting tires anyday now...meaning Ill be going to buy em soon as I find out if they'll fit,hince the reason Im asking.
B/c that is a logical assumption in the way you wrote it. So I can assume to the best of my ability. So, for the shop that you are going to purchase, what was their response to your query?
Old Nov 29, 2011 | 01:10 AM
cutthroatxxx
The kid up there said....I dont know maybe you cab look it up.Then he got someone else&he said I would think so.But that didnt suit me
Old Nov 29, 2011 | 01:13 AM
jdh0921's Avatar
jdh0921
from what I've looked into it.. 265/75/r16 is the highest that will go on those rims. Any higher like wh1te said, they will refuse to mount them, or charge extra and not give a warranty on the installation. Also you'll have to probably get spacers if you go higher, because you probably will have a rub.
Old Nov 29, 2011 | 01:18 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Merc is most likely right since its based on the tire minimum specs.
Additionally, you'll find other similar responses.
http://lmgtfy.com/?q=max+tire+width+on+16x7+wheels
Since you got that type of response from the shop....I personally would not go there.
Old Nov 29, 2011 | 01:19 AM
cutthroatxxx
I may just order a new set of wheels will a 16x8 with a 4.5 back spacing be ok?
Old Nov 29, 2011 | 01:49 AM
biggreen2500's Avatar
biggreen2500
just for the record i've ran 315x75x16 on the factory wheels... thye rubbed a little but worked good... had them on there for about 10 months before up grading to 18s and then 20s lol
