Wont start when wet out??
Old Nov 30, 2011 | 11:11 PM
THEGOLDPRO's Avatar
THEGOLDPRO
Default Wont start when wet out??
Hey guys my 98 5.9 gasser wont start when its wet/damp out, it will turn over and over and over and chugg sometimes, and if by the grace of god it does start it runs on like 6 cylinders till it heats up then will run fine. I assumed it was the cap so i replaced the cap and rotor and that did nothing it still wont start. When its dry it fires right up first crank.
Is their anything else that would affect the starting when wet?
Old Nov 30, 2011 | 11:43 PM
Mater's Avatar
Mater
The distributor itself could be another place to look. Have a Grand Am the same way and thats whats wrong with it. Beyond that I dont know these trucks well enough to give you anywhere else to look.
Old Dec 1, 2011 | 12:54 AM
stev's Avatar
stev
Simple. Take a hairdryer to the PCM for about 5 mins. Crank over the engine, it should start. Either the connectors have gotten moisture in them to the PCM or the PCM PC board is going bad.
Old Dec 1, 2011 | 07:52 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Bad/worn plug wires.
Old Dec 1, 2011 | 07:57 AM
kadetklapp's Avatar
kadetklapp
Do the 5.9 gas motors have a coil in the traditional sense?
Old Dec 1, 2011 | 09:40 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
By "traditional" do you mean biblical?
Old Dec 1, 2011 | 09:53 AM
What's a biblical coil?
No start when wet is generally a secondary ignition circuit problem, cap, rotor, or wires. (sometimes, but very rarely, plugs.)
Old Dec 1, 2011 | 07:11 PM
THEGOLDPRO's Avatar
THEGOLDPRO
I will start simple and check wires first i suppose.
Old Dec 10, 2011 | 12:27 AM
THEGOLDPRO's Avatar
THEGOLDPRO
changed the ignition coil and the wire going to the disty from it and it starts right up now, thanks guys.
