posi-lok cable 4wd pops out
Old Dec 7, 2011 | 04:30 PM
yellowtruck's Avatar
yellowtruck
Default posi-lok cable 4wd pops out
I bought the cable operated kit for my 1500 and i cant get it to stay locked in 4wd it keeps popping out even if i hold the cable it still pops and disengages front axle?!!! Any ideas?
matt
Old Dec 7, 2011 | 04:35 PM
Does it engage all the way? I guess the "posi" in that name isn't quite as accurate as it could be...... There really shouldn't be any lateral stress on it......
Old Dec 7, 2011 | 04:44 PM
byronpen's Avatar
byronpen
I had the same problem, adjust the cable that screws into the housing on the axle, thats what i did to fix mine
Old Dec 7, 2011 | 06:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can screw the **** in or out to adjust the cable. But the **** needs to be in a certain position before adjusting the cable down by the CAD. A little detail that is left out of the crappy directions. Needless to say, someone else on DF owns my Posi crap I mean Lok.
Old Dec 8, 2011 | 06:48 PM
plott hound's Avatar
plott hound
i got one and works ok.found it easy to adjust but hard to engage and disengage.dont want to get stuck then try to engage it i tell u that.
Old Dec 8, 2011 | 07:04 PM
The idea is, put it in 4x4 BEFORE you really need it.
Old Dec 8, 2011 | 08:58 PM
Terribly's Avatar
Terribly
Thats just a minor detail though... Not important lol
Old Dec 8, 2011 | 11:59 PM
97tn4x4's Avatar
97tn4x4
I'd be the fellow member that owns zmans posi lock lol. I screw mine in and out. I always lock the front axle in while slightly rolling before I go through anything. That way if I need it I can just pull the do not get stuck lever back.
Old Dec 9, 2011 | 04:37 AM
zman17's Avatar
zman17
Oh yea it's you. It worked fine, I just didn't like having to do something else. When keeping up with the Vac lines is easy. Plus I don't wheel.
Old Dec 10, 2011 | 10:17 AM
dhvaughan's Avatar
dhvaughan
+1 on this, i'm guessing on direction - but try screwing the adjustment in, so the cable pulls the fork MORE to the drivers side for deeper engagement of the collar onto the intermediate shaft.
for anyone with difficult engagement of the collar - this will occur irregardless of vac or cable operation. tight is tight. the collar slide can be tight due to either bushing/bearing misalignment at the axle half junction, or due to burrs on the axle splines or collar. you have to pull the outer axle out a little to get to the small bushing or collar. you have to pull it all the way out to get the damn inner axle half out. you can remove burrs with a small file. if it slides back and forth easily with finger pressure, then the cad mechanism can work right. if it doesn't slide easily with finger pressure, then the cad won't work worth a flip either.
