msd box hook up
Old Dec 12, 2011 | 08:46 PM
dipsherry's Avatar
dipsherry
Default msd box hook up
well i had one on my old rig and loved the difference it made. so i got one for my new truck...but for the life of me i cant figure out how to wire it up. and i know a few of u guys run them anyone mind telling me how you wired urs up
Old Dec 12, 2011 | 09:08 PM
J415's Avatar
J415
what model MSD?
Old Dec 12, 2011 | 09:15 PM
dipsherry's Avatar
dipsherry
the digital 6al box
Old Dec 12, 2011 | 09:25 PM
J415's Avatar
J415
http://www.summitracing.com/parts/MSD-6425/?rtype=1
Hope it helps. If not, pm Aims. I'm pretty sure he has an msd box on his rig.
Old Dec 12, 2011 | 09:31 PM
silverlakexj's Avatar
silverlakexj
and post up about how it helps and by how much and if you felt it was worth the money. I would love to hear about it.
Old Dec 13, 2011 | 08:33 AM
dipsherry's Avatar
dipsherry
thanks i was trying to remeber like hell who had one.
Old Dec 13, 2011 | 08:35 AM
dipsherry's Avatar
dipsherry
had one on my old truck i felt a difference mainly in startup and mpgs and a little bit down low. If your looking to make big power for the money this is not the way to go but if your doing it as a supporting mod it works wonders. for me the box cost less than $200 so it is worth it with the lil mpg gains and lil hp
Old Dec 13, 2011 | 10:10 PM
silverlakexj
Thank you for allowing me to hijack this a bit. I have a completely stock 5.2L. I am going to do VERY little to it, I am looking to up my mpg and get some more torque. What sort of mods work best with the MSD box? Thanks
Old Dec 14, 2011 | 08:45 AM
dipsherry's Avatar
dipsherry
it all goes pretty much the same
plenum
timing chain
sct if your obd2 or mopar performance ecu if obd1 like me
make sure all maintnece is up to date. this should be first
1.7 roller rockers
intake
And on other hand the box still didnt work no matter how i wired it...called msd said i have to get the tach adapter to get it to run.....we wil wait on ups now and see
Old Dec 14, 2011 | 08:56 PM
CPTAFW163's Avatar
CPTAFW163
I have one, it is simple:
Page 16 second diagram
http://static.summitracing.com/globa...5_frm29772.pdf
1. Cut your ignition wires about 10 inches from the coil plug.
2. Connect ignition wires to box wires (ones from diagram that has the ignition signal sent TO the box, green/orange to red, and black to white)
3. Connect ignition wires (10 inches and plug) to the wires that come OUT of the box (diagram green/orange to red, black to black).
4. Connect the MSD box pos and neg wires to the battery.
5. Use 3M double sided tape to attach your 6AL box to the top of your PDC cover.
**Easy way to know the correct colors is to connect the black to black and white to black**
That is how I did it. You can either CUT the wires that are supposed to go to the distributor.
With the quick connects, it takes me 5 mins to take my MSD in and out of the truck. 2 mins to just do a disconnect.
Be prepared to not notice much other than it takes 3 turns longer to start your truck. I only have it in there because it looks cool. No increase in MPGs. BUT, you get better acceleration at WOT.
The Non-professional MSD systems don't work like people think they do. MSD started making crap after they went mainstream. People think they burn all the fuel in the chamber. THat is impossible....it would mean detonation. The more fuel the ignition burns, then the more fuel has to be put in to ensure the right mixture.
You won;t notice any power difference. Maybe smoother acceleration.
BTW, I also put male/female ends on all my connections so I could disconnect the box QUICKLY if it ever went out. Solder all connections as well.
