98 belt chirp
98 2500 with 360 @ 240k
in the spring i replaced the water pump due to a bad bearing. Prior to this the truck kept eating belts due to about .75" of play in the water pump pulley (no leaks) I replaced the pump, put on a Gates tensioner, idler pulley, and Dayco belt. Life was good for about a month when the water outlet developed a leak so I put in a new outlet, t-stat, and gasket. The belt chirped for awhile I am assuming to spillage of anti-freeze, but since I had a lifetime warranty i changed the belt and all was good again for a couple weeks. The hose at the top of the radiator must have died and i got a slight leak, so i used a worm gear hose clamp instead of the pinch clamp, but that got the belt wet again with anti-freeze so once again i changed it. Now I have chirp again, but I have looked all over and I do not see any signs of leaks. I saw another thread about pully alignment so I am going to check that tomorrow. I do notice the belt tracks to the rear of the pully. I wondered if anyone else has seen this. NOTE: I always washed the anti-freeze off of the vehicle, I know some people simply let it dry - not me. So I know it is not the fan blowing residual on the belt, but maybe there was some anti-freeze on the pully's still causing some glazing?
the belt feels dry and all but leaves residue on my hand similar to when you rub your fingers over oily bolt threads
pics
http://www.flickr.com/photos/1275873...851139/detail/
pics
I had a leaking water pump for a while which was causing a belt chirp/squeal.. I replaced the water pump and started the truck to gear the same thing and I narrowed it down to the idler pulley is on its way out. Hope this helps ya some. Take a good look at all the pulleys and maybe put some kind of chemical on them just to rule them out from squeaking. If that dont work maybe try a new belt
Belt chirp:
http://www.youtube.com/watch?v=X9qMtVVLXeY
Belt squeal:
http://www.youtube.com/watch?v=sli3F...eature=related
Second time in a week i posted those.
Belt squeal:
pics
pics
Trending Topics
i notice my radiator jug is running a little low - its got to be anti-freeze leaking from somewhere but I cant find it. Also when I swapped the thermostat I put a 180* stat in, I am going to switch it back. What your thoughts?
