Heater not working very well at idle.
I don't think there is much difference between them. The radiator flush I used was just some variety of salt.... (don't remember if it was calcium, or potassium....) CLR is pretty much the same thing. Its just a descaler.
i havnt used that garden hose in months. even before the freezing weather.
i have another question though.
I used this product to clean my cooling system. and it says to draind and fill with water and add the cleaner and drive for 3-6 hours. driving can be spread across a few days. If i do that out here my system will freeze up. How should i handle this? could i add some anti freeze or what?
Does this flush say to leave it for a couple of days driving or you can. Most of them I have used say to flush system, put in cleaner fill up with water dirve for 15 min to 1/2 hour, drain system, flush with water and then refill with antifreeze. I agree with not using the one for days. if its plugged up enough for that one the heater core needs replaced anyway
I used the multi-day flavor on my van. The coolant was a nice color or red..... (rust from the block.) I left in it there for a week.... flushing the old crap out of the system took a while. I suspect I need a new water pump as well, as the flow coming out the upper radiator hose with the engine running was hardly a trickle, even when the thermostat opened. Coolant is nice and clean and green now though, and the heater works a HELL of a lot better.
