i need help 99 2500 360
Old Dec 14, 2011 | 03:45 PM
dwebby94's Avatar
dwebby94
Exclamation i need help 99 2500 360
my truck missfires a little bit after it hits normal running temp, goes away after awhile, new plugs wires cap rotor coil, no check engine light, i need help thanks guys
Old Dec 14, 2011 | 04:01 PM
'nother member from michigan. Welcome to DF.
How old is your O2 sensor? Might try just unplugging it, and see if the truck drives better.
Old Dec 14, 2011 | 04:26 PM
kejobe's Avatar
kejobe
Plug wires routed per TSB? https://dodgeforum.com/forum/2nd-gen-ram-faqs-diys-and-how-to-s/292412-tsb-18-48-98-proper-routing-of-spark-plug-wires.html
Old Dec 14, 2011 | 09:10 PM
dwebby94's Avatar
dwebby94
it has been doing this before i replaced the wires and every thing else but an hour ago i took out my stock kn air filter, i went and got a 7 dollar filter and the problem seemed not as pronounced or didnt miss as bad idk this is startin to chap my a$$$
Old Dec 14, 2011 | 11:29 PM
gdstock's Avatar
gdstock
So, are they reouted per TSB as kejobe mentioned? Were they routed correctly before?????
Never saw a misfire caused by an air filter....... But who knows? There is a saying, "there's a first time for everything!"
Unplug O2 sensor, or pull it out? I vote pull it out...
Old Dec 15, 2011 | 10:30 PM
dwebby94's Avatar
dwebby94
ill try the tsb and o2, but my buddy that is a cummins mech. said he was sure it was a fuel pump and come to think about it last summer befor the tranny gave out i only put 10 or 20 bucks in at a time so hell maybe that or just the fuel filter
Old Dec 15, 2011 | 10:41 PM
gdstock's Avatar
gdstock
I think fuel pump would cause stalling before misfire.......not 100% on that, but not my experience.
Old Dec 15, 2011 | 10:45 PM
SpecialistBoicourt's Avatar
SpecialistBoicourt
a restriced fuel filter CAN cause a misfire.
Old Dec 15, 2011 | 10:46 PM
SpecialistBoicourt
the hall effect module under the cap & rotor can cause as well
Old Dec 15, 2011 | 10:47 PM
gdstock's Avatar
gdstock
That is the cam sensor, and it can cause misfire. I think it would throw a code.
