part number for 4WD 4-port vacuum harness?
Old Dec 15, 2011 | 03:35 PM
kbizzle's Avatar
kbizzle
Default part number for 4WD 4-port vacuum harness?
i'm looking for the part number of the 4WD vacuum harness that connects to the transfer case switch. mine is leaking. i've temporarily fixed it with a large zip tie that tightly clamps the harness to the switch.
for the past couple of weeks i've been searching online for a replacement but i've had zero luck. maybe i'm not searching for the right keywords? here's a photo i found online of the harness:
i called my local dealership and the guy on the phone had no idea what i was talking about. he asked for a part number (which i don't have) and then said it was "probably discontinued."
any help would be greatly appreciated!
Old Dec 15, 2011 | 05:11 PM
dlyter09's Avatar
dlyter09
Im not sure of the part number but a junk yard might have what your looking for if you cant find it somewere else
Old Dec 15, 2011 | 05:16 PM
kbizzle's Avatar
kbizzle
thanks, man. yeah, i don't have a lot of great JY options around here but that may be what i'm up against.
just seems like a pretty common part and hopefully i can purchase somewhere online or at the dealer.
Old Dec 15, 2011 | 05:20 PM
UnregisteredUser's Avatar
UnregisteredUser
I don't have the part number, but got mine at the stealership about a year ago. Sometimes it pays to just walk in so the counter guy can get a mechanic involved who knows what the part's called.
Old Dec 15, 2011 | 05:25 PM
Or look at the pretty pictures the parts guy can show you, and point at what you want.
Old Dec 15, 2011 | 06:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Or look in the FAQ/DIY section and look in one of the parts manuals for the actual number! https://dodgeforum.com/forum/2nd-gen...s-manuals.html
Old Dec 16, 2011 | 10:11 PM
kbizzle's Avatar
kbizzle
thanks, zman. i actually DID look in the parts manual before i asked. it's not clear to me from the drawing. it may be #52078361.
i'll drive to the dealership and see if i can get someone there to find it. i'm just glad to hear that it is still available for purchase. whenever i finally do get the part, i'll report back with the actual number.
Old May 2, 2012 | 09:44 AM
kbizzle's Avatar
kbizzle
as a follow up, i finally went to the dealership yesterday to pick up a couple PCV valves. while i was there, i asked about this vacuum plug/harness. it took 2 guys on a computer about 20 minutes to confirm the correct part number:
52078361 HARNESS A - $27.20
the part includes the rubber 4-port harness and the complete snake of vacuum lines (red, black, gray and green). you can't just replace the rubber plug. while the zip tie clamp band-aid has worked well the past few months, i'm going to replace the harness and vac lines this weekend with the new set.
Old May 2, 2012 | 10:05 PM
johnnyjaws98's Avatar
johnnyjaws98
just put some atv sealent on the male plugs and slip it in let it dry youll have no! leaks
