Odd problem HELP
Old Dec 16, 2011 | 03:37 AM
Fubba's Avatar
Fubba
Default Odd problem HELP
I'll do my best to explain this. It's on a 96 5.2.
It's happened once before a few months back. Just got home from a 300 mile drive on the interstate. About 90 miles from home, everytime I let off the gas slowly, the truck would jerk and the rpm's would kind of jump around. When I pressed the pedal again, it would do the same thing until the pedal was pushed down to a certain point where I was just cruising along. Speeding up from this point was fine. It does it with O/D off as well, it's just much more violent because the RPM's are up higher. It's hard to start, and also when starting from a stop, the RPM's will jump down like it's about to die, and I have to give it a good bit of gas to stay on. Now the last time it did this, I disconnected the battery overnight, and the next morning it ran great. Tonight I pulled over at a gas station and disconnected it for about 5 minutes, but it didn't help. Also, the check engine light isn't coming on.
The motor and tranny were rebuilt about 60,000 miles ago. I put in a 180 degree thermostat just for giggles, but it's been running really cold. I'm going to change that out this week back to a 195. Could it be that it's just gummed up from running rich? Any ideas here? Crank or cam position sensor? IAC or EGR valve?
Old Dec 16, 2011 | 04:27 AM
97tn4x4's Avatar
97tn4x4
Could be the IAC or the TPS.
Old Dec 16, 2011 | 04:56 AM
peshewa's Avatar
peshewa
If you live in a cooler climate area, put the stock thermostat back in. Otherwise it will take a lot longer to warm up & not run at the correct temp to make everything happy. As for as your issue, I would first check all electrical connections like both battery cables. After that, do the tests on the IAC & TPS, there should be some stickys on those tests. If that does not do it, I would suspect the EGR. Someone correct me if I am wrong, but the EGR in this truck is still vacuum advanced, right? If it is not the electronic EGR, it could have a heavy carbon build up causing the rod in it to not move, causing issues similar to yours. Cleaning it would work or replacing it, but I vote for doing tests correctly before throwing $$$$ at it that it may not need.
Old Dec 16, 2011 | 03:24 PM
Ramzy's Avatar
Ramzy
I saw the same issue in my shop on one of our trucks. I would def look at the TPS. If you have to replace it make sure you disconnect the batt first.
Old Dec 16, 2011 | 04:20 PM
Fubba's Avatar
Fubba
Stock therm is definitely going back in. I'll try those tests. Thanks guys.
Old Dec 16, 2011 | 06:35 PM
bwdakrt's Avatar
bwdakrt
You could also have some water in your gas tank. Pour in a bottle of HEET water remover just in case.
Old Dec 19, 2011 | 04:00 PM
Fubba's Avatar
Fubba
Ok guys...I tested the TPS. The voltage was 0.7 at idle and rose up slowly and steadily to a max of 3.5 volts as the gas pedal was pressed all the way to the floor.
Anything else I should try?
Old Dec 19, 2011 | 07:11 PM
Pull some of your plugs, and see what they look like. Did you use a digital, or analog meter to test TPS? (It sure SOUNDS like a tps problem......)
Old Dec 19, 2011 | 10:24 PM
Fubba's Avatar
Fubba
I used a digital. It didn't jump down or up. Rose by .1 to .2 volts as it was being pressed. Is a max of 3.5 volts ok? I thought it was supposed to start between .8 and 1.2 then go up to at least 4 volts.
I'll pull a couple of plugs in the morning when I can see.
Old Dec 19, 2011 | 11:50 PM
gdstock's Avatar
gdstock
Did you check volts or ohms on TPS? I am assuming volts, with key on? Disconnect battery, remove TPS and read ohms from closed position to fully open. Make sure there are no skips and ohms increase proportional to movement.
