5.9 starting problems
Old Dec 16, 2011 | 08:54 AM
edsha1's Avatar
edsha1
Default 5.9 starting problems
Let me begin to thank all of you who help others out, I read alot of the reply post on other starting problems some have been having. I think this one is odd tho.
Not long ago, I was heading out and heard a loud clunk , almost like a animal was in the engine area when first start and they tryin to get out.. looked into mirrors didnt see nothing.. stopped an put some gas in went on my way. Next morning temp dropped to 22 degrees. Nothing new to me ! Went out to start truck up wouldnt start over, it would crank just not catch. Check distributor, notice the black scaring from starting, cleaned that off, check rotor button, same thing,, cleaned that off, check ignition coil, looked cleaned, cleaned it anyways. Tried to start, nothing. As the Temperature got warmer, think it was 40 out, truck started. Took fiance to work, came home, shut it down, waited like 30 secs, started backup. About 2pm had to go back out, went out to start truck,,nothing! I finally took my little heater, put it inside the engine compartment, let it sit for 10 mins or so, tried starting, it started. Got back, shut it down,waited a few and it started. Checked it the evening, it started,come morning nothing. Put heater back inside, waited 5 mins, truck started. Now, it doesnt matter if I use heater, truck wont start. Have a few ideas that I got from you all, just tying to narrow it down. Odd thing is, no trouble codes !!
Could use any help you might have.
Old Dec 16, 2011 | 09:48 AM
Last time I saw an issue that started out that way, the PCM was bad......
Old Dec 16, 2011 | 10:03 AM
edsha1's Avatar
edsha1
any way of checking to see if it is ?
Old Dec 16, 2011 | 10:05 AM
Grab a PCM from a similar truck from the junk yard. Swap it in, see if the problem goes away. If it does, get it flashed for your truck.
Old Dec 16, 2011 | 10:32 AM
edsha1's Avatar
edsha1
The Dealers are the only ones that can flash it correct?
And I would need vin# for truck to match?
Old Dec 16, 2011 | 11:17 AM
You might be able to find an indie shop that has the ability to reflash the PCM. Not sure if they could reset the vin for it though.... call around, see what you can find out. The dealer most certainly has the ability, whether they WILL or not remains to be seen, some of them get picky about where you got your PCM from, and will only reflash PCM you buy from them. (for half of what the truck is worth......)
Yep, VIN in PCM needs to match the truck. Makes things friendlier that way.
Old Dec 25, 2011 | 10:42 PM
wardom32's Avatar
wardom32
New Member
When my 5.9 wasn't starting, and it was stalling when it was idling I had to replace the distributed and the crank sensor, now it runs fine. Good luck!
Old Dec 26, 2011 | 12:25 AM
gdstock's Avatar
gdstock
I wonder if OP got this fixed and if so what the problem turned out to be.......
Old Dec 29, 2011 | 06:39 PM
edsha1's Avatar
edsha1
well, seems that a total tune-up did the trick, replaced cap,button, plugs and wires. Starts every time, but have yet to drive. still need to replace tie-rods and do brakes. Want to thank all for some interesting advise, just glad it was a simple task.
