Dodge Front Ends
Old Dec 19, 2011 | 06:08 PM
  #21
EvanBoothe123's Avatar
EvanBoothe123
It is Deffinitly loose I will tighten it after work I thank you all for the help this fourm is awesome
Old Dec 19, 2011 | 06:14 PM
  #22
EvanBoothe123
There both loose
Old Dec 19, 2011 | 06:20 PM
  #23
BackwoodsRam's Avatar
BackwoodsRam
id go ahead and check all of your mount just to be on the safe side, can you post a pick of what your body mounts look like. it may be time for new bushings
Old Dec 19, 2011 | 06:46 PM
  #24
Re-torque the lower shock bolts.
Old Dec 19, 2011 | 07:45 PM
  #25
gdstock's Avatar
gdstock
Originally Posted by EvanBoothe123
Why do you mean banging?? Explain that please.
Hitting the end of the stroke on the shocks - either end - fully extended or fully compressed. Either situatiojn would be bad. May have to go to longer stroke shock if that's the case.
Old Dec 19, 2011 | 10:41 PM
  #26
EvanBoothe123
Oh like the shock is fully extended sitting flat and when I hit a bump or my axle flexes the shock bangs because it is fully extended. How would I check this what would be the easiest way,
Old Dec 19, 2011 | 10:42 PM
  #27
EvanBoothe123
Tomorrow I will tighten the bottom bolts on the shocks and run over all of the bolts just to check everything. Thanks guys.
Old Dec 19, 2011 | 10:43 PM
  #28
EvanBoothe123
I can get a picture up here tomorrow it's dark out now.. Damn Ohio winters. Is there just the 2 mounts in the front of the truck? is there any like by the wheel wells up front?
Old Dec 19, 2011 | 11:08 PM
  #29
Aubrey's Avatar
Aubrey
Behind the wheel well. You'll see them. They are hard to miss.
I doubt just driving down the road with a 3" lift you are over extending your shocks, but if you've never replaced them you should with as old of a truck you have.
It could just be your body mounts. Could be some of your bolts on other parts aren't tight enough. A big one for me would be all of the bolts around your shocks.
For control arms you shouldn't get much noise with the angle. It just alters your pinion angle. Knocking from them you'd feel in the floor board.
A bad track bar causes wander and not so much a knocking noise.
Old Dec 19, 2011 | 11:10 PM
  #30
EvanBoothe123
Behind the wheel well as in like above the control arms?
