Dodge Front Ends
Old Dec 19, 2011 | 11:18 PM
  #31
97tn4x4's Avatar
97tn4x4
Right behind them.
Old Dec 21, 2011 | 11:25 PM
  #32
99dodge318's Avatar
99dodge318
Could also be your sway bar bushings have worn away, so every time you hit a bump it hiys your frame.
Old Nov 4, 2012 | 04:51 PM
  #33
floydslifted97's Avatar
floydslifted97
sounds like control arm bushings on the axle side bad..with that big of a spacer on stock arms u should stock up on control arm bushings!
Old Jan 20, 2013 | 01:26 PM
  #34
Ron Boosel's Avatar
Ron Boosel
I just lifted my 98 ram 4x4 with 35in. tires as well and was reading along here and thought maybe i can get some good info. So far all i had done was the lift, i know i want/need duel steering stablizers. What else should i upgrade to avoid large problems? I expect the normal wear out items to wear faster. I have a lot of steering wheel play and a small rubbing sound coming from drivers front wheel during a mild speed turn. Outside of lift and radio replacement truck is stock.
Old Jan 20, 2013 | 04:42 PM
  #35
95RAM360's Avatar
95RAM360
i think i have the exact same thing going on as what you have, and i know its my control arms because my wheel bearings, tie rods, ball joints, pitman arm, and shocks are all new....and my bushings are dry cracked.....its only like $40 for a control arm with bushings from rockauto...replace all 4 for less than 200 bucks....not a bad deal Imo
