Heater Core Installation
Old Dec 23, 2011 | 10:28 PM
  #21
chadhager03's Avatar
chadhager03
No my friends standard cab 97 ram dash is in pieces
Old Dec 24, 2011 | 01:59 AM
  #22
Hjhf1500's Avatar
Hjhf1500
They have aftermarket reproductions?where?
Old Dec 24, 2011 | 07:31 AM
  #23
Gary-L's Avatar
Gary-L
Veteran: Navy
https://dodgeforum.com/forum/2676099-post20.html
Originally Posted by VWandDodge
Actually, he's better off spending the money for an aftermarket reproduction of the dash top (not a cover) that's made of more durable material. There are plenty of threads here that detail them.
I wouldn't waste $20 on a junkyard dash. All you're doing is buying the same worthless POS you just removed.
Old Dec 24, 2011 | 11:05 AM
  #24
Hjhf1500's Avatar
Hjhf1500
Ha Ha Ha very funny wise guy lmao. but seriously though I didn't know they had aftermarket reproductions thanks for the info.
Old Dec 24, 2011 | 09:13 PM
  #25
gdstock's Avatar
gdstock
Check this Thread. I think I included link to supplier.
https://dodgeforum.com/forum/2nd-gen...n-cracked.html
Old Dec 25, 2011 | 02:36 AM
  #26
Hjhf1500's Avatar
Hjhf1500
Thank you sir,that looks alot better and durable then the original and the flimsy glue-on ones,it's expensive but worth it.Merry Christmas!
Old Dec 26, 2011 | 06:58 PM
  #27
soloflite's Avatar
soloflite
B4 you all go buying the dash top, remove your old and inspect the rest of it. You can find them on Ebay for about $150.00 Underneath the top bit is also plastic, mine was broken in multiple places and a simple top was not all I needed, I wound up spending 20$ at the JY, yes $20, on another dash. Only thing cracked is the mounts for the drink tray, but will do something up w/ that using some sheetmetal to re-inforce it before I re-install my new dash.
also the dash I pulled came from a 94'. so I had to swap the wiring harness from my old one to this one, as ODBII didn't start until 96, and needed the ODBII port.
Spent all day today on the Ram. got the new heater core in, did the cut method as mentioned here, was a little tough getting the new core in, but once I figured it out, it went right in.
Also wound up keeping the existing water pump, believe it was leaking at the RTV seals or at the bypass hose that runs from the top of the water pump to the intake. Wound up w/ new hoses all around.
Just need to install the dash tomm. top er' off w/ antifreeze, burp er' and take it fer' a test drive. Hopefully no more antifreeze leaks...
Old Dec 26, 2011 | 07:03 PM
  #28
soloflite's Avatar
soloflite
Your probably right, however the plastic that the dash tops mount to is also all broken up, a whole new dash is needed. even If I buy a dash top, and I did price them, I'd not be able to install it w/o a good underneath that isn't broken as well.
Dodge really didn't think on this one, plastic dashes on 4x4 trucks, what were they thinking.. Wish I could find a metal dash from the 60's that would fit..
Old Dec 26, 2011 | 07:42 PM
  #29
stewie01's Avatar
stewie01
Two words: Custom Fabrication
