vacuum leak.. wheres this supposed to go?
Thank you! being that its hvac... that must be whats causing the wild vents... when putting in a new line where would i connect it after putting a new line from the T piece
I looked under the battery tray everything seems in tact... if i remember from what i heard thats where the cruise control vacuum line is... I cant check to see if the cruise control is working because i im in the belief that i need a new clocck spring (my horn doesnt work either)
so these next two pics that im posting my question is are these two supposed to be connected???
I have a nice diagram that was posted (thanks by the way for that link)
If you could send that picture to my email that would help too. All the info i could get (can never have too much knowledge)
my email is treya.murphy@yahoo.com
thanks for all the help once again everyone
Alright I just worked on the vacum system on my truck because the header I had broke and it melted my lines into. So I had no 4wd at all. I went hunting to find the problem. The little black peice on top of the distibuter is the vent. Its suposed to be there. Theres two lines to and from the trans from the hood area. Ones vent, and one is vacum. The one thats broke is the vacum. go under your truck and youll find these lines in a wire loom going up beside the exasht to that area. If you find the broken one just goto autozone with that broken end and they can get you a rubber hose to fit onto it and you can splice it properly. if you need more help I can take pics tomorrow as it is raining here today.
Thanks,
Cheat.
Thanks,
Cheat.
