ABS/ Brake issue = Wheel Bearing?
Old Dec 24, 2011 | 10:37 AM
DodgeLooney00's Avatar
DodgeLooney00
Exclamation ABS/ Brake issue = Wheel Bearing?
So, after tirelessly searching to no avail, I gueess I'm the first to post about this issue? Anyways...
So back in April, I went on leave and bought My truck (See Sig.) and I did my services on it, of course. (Oil, Oil Filter, PCV, Air Filter, Spark Plugs, etc.) And everything was good. But every once in a while, when I hit the brakes, it'll act like the ABS is going off, and do that shudder thing like it's pumping the brakes. It's good on fluid, no leaks, just... that. I'd say it does it every 1 in 12 times.... I just thought it was because of the oversize tires messing with the controller. But, when I got back to Germany, one of my Dodge buddies said that it was the front wheel bearings causing this problem. No ABS lights are on or come on (They do at startup, so I know the bulb is good.) Anyone else have this issue?
Old Dec 24, 2011 | 10:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Do you have 4 wheel ABS?
Old Dec 24, 2011 | 11:02 AM
DodgeLooney00
4 wheel ABS, but to be completely honest with you, I can't recall whether I had discs or drums out back.... it's base of base models, so i'm thinkin drums...
Old Dec 24, 2011 | 11:10 AM
zman17's Avatar
zman17
I think your best bet would be to take it some place that has a scanner capable of reading ABS codes. See if there are any stored codes. You can also try this and see what if anything comes up. https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Dec 24, 2011 | 12:57 PM
DodgeLooney00
Thanks for the advice, when I see her in about a year, I'll take her to the shop...
Old Dec 24, 2011 | 01:13 PM
zman17's Avatar
zman17
Raise the front and check the wheel bearings. Also try that key trick for the codes.
Old Dec 24, 2011 | 05:23 PM
Key trick won't pull ABS codes. Need a reader for those, and I don't think the parts stores can/will pull 'em either.
Old Dec 24, 2011 | 06:36 PM
zman17's Avatar
zman17
I know , I was just curious if anything would come up if he tried it.
Old Dec 24, 2011 | 10:17 PM
CPTAFW163's Avatar
CPTAFW163
Gonna have to wait a year, he is on deployment until he comes back and can actually see his truck. Maybe he can take a look when he cets back for mid tour leave.
He probably won;t see these replies for another few days. I wan only on the computer every 3 or 4 days.
Old Dec 25, 2011 | 12:09 AM
DodgeLooney00
Unfortunately, I'll be heading back to Germany for R&R, so it'll be the full year... Only 318 days to go! But thanks for all the advice. I wasn't sure what to think with the wheel bearing thing, but I suppose it's possible if it making the axle wobble... When I get back I'm going to do a fuller service on it, since I'll have more time. Axle bearings and seals (both axles), diff fluid change, Trasfer Case Fluid Change, Tranny Flush/refill/band adj. ,Radiator flush, plenum fix, all new brakes, new water pump, new radiator hoses, etc...
