Excessive Positive Camber
Old 01-21-2012 | 09:57 PM
CSCustomCars's Avatar
CSCustomCars
Originally Posted by Wh1t3NuKle
So what do you think caused the excessive toe-in?
Dealership I bought the truck from put a whole bunch of new front end parts Tie rod ends and such, and the shop he had do the work (small dealership) said they did an alignment, which obviously they did not. But I did see the parts when I bought the truck and they were very obviously new. But I undercoated the whole truck so they look old now. I know I didn't hit anything that would make the toe go out that far, so all i can think is that shop just didn't do an alignment to begin with.
  #52
Old 01-22-2012 | 12:29 AM
gdstock's Avatar
gdstock
OP stated that tie rod ends were new...so I suspect it was off when replaced. I use a toe in plate whenever I do any front end work.....then take in for alignment. Always thought about getting caster/camber set, but only think about it when in need!
Quick Reply: Excessive Positive Camber
