Fuel Pump Check Valve
Well it seems like my Fuel Pump Check Valve has gone, one day the truck started first time every time, now it takes an extended time or 2 or 3 ignition turns to get her started, I did the test with a fuel pump pressure tester and it lost pressure within a short while, no leaking from injectors or anywhere else, I can live with this for a while as money is tight at the moment.
So a couple of questions:
1) Rough idea how long it will last like this?
2) Has anyone installed one of these http://www.amazon.com/gp/product/B00...A30DGJTMHYAU9C with success or is that a really bad idea?
3) Drop the tank, remove the bed or cut a hole in the bed to replace the pump?
Thanks..
Thanks..
It will continue to run like that till the pump dies. Could be next week, could be next decade. If your fuel pressure is still where it should be, this is one of those repairs that you don't ever have to do, if ya don't wanna.
I think the check valve is actually in the regulator/filter assembly on top of the sending unit. (external to the gas tank) You may be able to replace JUST that part, and solve the issue.
Check valve in the fuel line is a bad idea. It restricts flow, uses compression fittings..... (which I don't trust... ESPECIALLY on a brake, or FUEL line....) and will work the pump harder to flow gas around it.
Thanks..
Thanks..
After you get all the gas out of the tank, use a rag first to wipe out the bottom of the tank, then hot/warm water. Just dry it out good. This should be done in a open area, no open flames or smoking, grinding ETC.
Ok, i`ll leave it until it quits working, hope it lasts for a while and doesn't leave me stranded, been reading through a few threads, looks like removing the bed is the easiest / quickest to get the pump changed..
Thanks for the replies..
Trending Topics
When you do it, I would drop the tank. I just changed the fuel pump on my F250 by raising the bed and now I can't line it up quit right. Because of that, my truck makes a funny humming noise on the freeway that I verified is coming from in between the cab and the bed. You call though.
cut a hole in the bed...with an easy access its better for future minded being nothing lasts forever especially if its a lifer...im having the same problem took out my pump in the tank and went inline on the frame..but now theres no check so all the gas falls back into the tank due to gravity so the pump sucks a bit of air for the first ten seconds makes for a hell of a hard start in 10 below weather..
