4x4 wire ?
Old Jan 4, 2012 | 07:20 PM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default 4x4 wire ?
Okay so i had a problem with my 4wd, the light kept on flashing on and off, while changing my oil the other day i noticed the 2 wire's that come down from i think the t-case was only on one of those prongs that stick out of the vacuum actuator, my only question is when i pushed the wire back on those 2 prongs they dont seem to stay on very tight? anyone know a way i could keep them on tighter so it doesn't slip off again? thanks
Old Jan 4, 2012 | 07:23 PM
Vacuum lines...... Yeah, the little connector feller tends to degrade, and loosen up... mine have little zip strips around 'em to squeeze 'em tighter. It works....... but, that's about all I can say for it.
Old Jan 4, 2012 | 08:05 PM
chadhager03's Avatar
chadhager03
Hose clamps if you wanna get fancy
Old Jan 5, 2012 | 04:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yup, zip ties work great.
Old Jan 5, 2012 | 04:52 PM
Big_Purple_01's Avatar
Big_Purple_01
i have a question with my 4x4 i have a 2001 15004x4 and the 4x4 dosent really work that well what kinda problem and i dealing with?
Old Jan 5, 2012 | 05:01 PM
zman17's Avatar
zman17
Uhh, what does that mean? "and the 4x4 dosent really work that well" .
Old Jan 5, 2012 | 06:05 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Looks like he asked over here too.
https://dodgeforum.com/forum/2685409-post19.html
Big purple -- More information/description is needed. We don't know if you are referring to problems of the transfer case, like shifting from 2HI to 4HI. What are you doing in this case?
If its not getting into 4 hi, then there would be no 4 wheel drive. Or, if you are getting into 4 wheel drive, then describe what you think is the problem. Walk us step by step.
Old Jan 6, 2012 | 08:54 AM
Big_Purple_01
Well when i put it into 4hi it seems to be grinding and 4lo seems to be workign just fine i was just wondering what i should do it seems to be working in the drive way but i dont want to test it were it might get stuck. its just seems to be grinding what does that mean?
Old Jan 6, 2012 | 09:12 AM
Augiedoggy's Avatar
Augiedoggy
wow, how the hell are we supposed to know whats going on....
sound like what some women I know would say.... "it wont go" whats wrong and how much to fix it?
Old Jan 6, 2012 | 09:14 AM
Where is the grinding coming from? Front axle, or t-case?
