D Range Tires?
Old Jan 6, 2012 | 08:46 AM
BackInBlack43's Avatar
BackInBlack43
Default D Range Tires?
Going to purchase a new set of 315/75/16 tires next week sometime my question is would i be ok with d range tires? i know the trucks call for e but from what I've read else where d range would be fine. Gas truck so it doesn't have the extra diesel weight, and i never tow anything just occasionally throw a few things in the bed but nothing heavy.
Old Jan 6, 2012 | 09:18 AM
D range tires will reduce your load capacity, but, that's it. Pay attention to your weight (of the truck..... not your waistline.) and you will be fine.
Old Jan 6, 2012 | 11:03 AM
redheadhunter21's Avatar
redheadhunter21
D load range is plenty for a 2500, both D and E load ranges are for 2500 and 3500 trucks, load on a D range is maxed out around 2500 pounds at the minimum
Old Jan 6, 2012 | 05:41 PM
BackInBlack43
LOL @HeyYou but ok sweet thanks for the responses guys, figure being that i don't need the e range tire i can save myself a little money
Old Jan 6, 2012 | 06:27 PM
HammerZ71's Avatar
HammerZ71
I've run nothing but "D" tires on four different trucks over the last 16 years, including a Ford 7.3 diesel and have never had any issues whatsoever...
Old Jan 6, 2012 | 06:29 PM
chadhager03's Avatar
chadhager03
I got e but that's because they were only like $100 more the the d, it was worth it to me
Old Jan 6, 2012 | 06:37 PM
kejobe's Avatar
kejobe
Aslong as you do not exceed the weight limit of the tires you can put any load range tires on you want.
Old Jan 6, 2012 | 06:46 PM
Hans_GZP's Avatar
Hans_GZP
I run D rated 315/70/17's on my 2500 and tow 10k lbs fairly often. No issues here.
