Nv4500 swap
Old Jan 6, 2012 | 10:01 PM
mccart's Avatar
mccart
Default Nv4500 swap
Will an nv4500 bolt right in place of a 3500?
Old Jan 7, 2012 | 10:02 AM
mrfarrell's Avatar
mrfarrell
yes....
Old Jan 7, 2012 | 10:12 AM
Sorta..... I think the issue you may run into is output shaft size/spline count, and length. May have to shorten the driveshaft.....
Old Jan 7, 2012 | 11:44 AM
mccart's Avatar
mccart
Ok thanks
Old Jan 7, 2012 | 12:14 PM
Hahns5.2's Avatar
Hahns5.2
I'm 99% sure they're the same length. I think the mount is in a different spot though.
Old Jan 7, 2012 | 09:40 PM
mrfarrell's Avatar
mrfarrell
1/2 tons never came stock with a nv4500..i swapped one into my truck..the only thing that was different is you need to get the shift tower and shifter with the nv4500...otherwise its a direct fit.....
Old Jan 8, 2012 | 12:07 PM
mccart's Avatar
mccart
Thanks guys, I think were going to put a 4500 in dads truck
Old Jan 8, 2012 | 10:46 PM
matt72991's Avatar
matt72991
Can u use the 3500 tcase with the 4500?
Old Jan 9, 2012 | 10:39 AM
3500 should have the NP241DHD. It'll bolt right up.
Old Jan 9, 2012 | 11:12 AM
BackwoodsRam's Avatar
BackwoodsRam
As long add the splines are the same size then yes
