"kalifornia" gross polluter !
Old Jan 7, 2012 | 05:37 PM
cj5orion's Avatar
cj5orion
Default "kalifornia" gross polluter !
'98 Ram 1500 5.9 magnum
recently tried to get it smogged......"gross polluter"
guy at the smog shop said to start with the o2 senser,maybe the cat.
I cant do the work myself, soooooo.....gotta take it to a shop for any repairs !
suggestions-comments-thoughts ?
thanx in advance !
OK...now I have some real issues goin on !
Because of the "wcrx #'s" on the emissions label,(under the hood).
There is not a replacement cat available !existing cat is probably bad...(exhaust smells rich)
How else can tell if your cats bad ?
Here in "Kalifornia",if your "wcrx" # doesnt match up,I cant buy a replacement cat ?
Could some of you guys check your emission labels on get back to me about your "wcrx #) ?
The label is right there by the hood latch when ya pop the hood
allowable wcrxa0360h31 /h32 /j31
mine wcrxt05.95b1
wcrxe0174gdh
Old Jan 7, 2012 | 05:38 PM
Is there a shop around that you trust?
Old Jan 7, 2012 | 05:57 PM
sam_priem's Avatar
sam_priem
take it to a shop to do o2's? thats like buying a new car because the oil needs to be changed..
Old Jan 7, 2012 | 06:25 PM
Augiedoggy's Avatar
Augiedoggy
All you need is to order the sensors online (or get them at the auto store for twice as much)... unscrew the old ones from your exaust and screw the new ones in them plug the connecter back in... its pretty easy (I just did mine)
if your cat really is clogged then you may have a blown plenum gasket of something else causing you to burn oil...Then take it to the shop. also seafoam / plugs wires cap and rotor cant hurt if its been a while..
Old Jan 8, 2012 | 10:04 AM
cj5orion's Avatar
cj5orion
thanx guys!
yea..I've been runnin seafoam...jus outa general purpose
thinkin about a diagnostic test ?????
Old Jan 8, 2012 | 12:16 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
co2 was high
thanx in advance !
Per your response, take it to a shop and be done with it. Not much further can be said on this.
Old Jan 15, 2012 | 10:20 AM
cj5orion's Avatar
cj5orion
Well it seems like "Kalifornia" has me boxed in as for smogability
interestling enough...I'm told if I claim a rural address for the truck I dont have to even get smogged at all ?
Anybody here in "Kalifornia" that could verify that ?
san diego area
Old Jan 15, 2012 | 10:30 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I could, but its appropriate for the owner to do it.
Old Jan 15, 2012 | 10:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
thanx guys!
Where are you putting the Seafoam? And if you don't mind me asking, why can't you replace the o2 sensors yourself? Also, does the sticker under the hood, say Federal or Cali emission. ?
Old Jan 15, 2012 | 10:39 AM
cj5orion's Avatar
cj5orion
sticker doesnt say either federal or cali ?
seafoam did the throttle body/booster one 3 mos ago
otherwise tank pours
