Cam change in progress w/pics.
i have read of some people using a long piece 1/2" threaded rod and large fender washers to press them out and back in. don't know how easy it would be.
the pics you have posted almost scare me enough to make me not want to replace the cam and lifters in my truck.
Found this posting and I'd say he was worse off then me: http://thespeedfreaks.net/showthread...3-Cam-Bearings
I think my experience can at least give insight to potential camshaft bearing condition. Galling being the primary degradation mechanism, most likely a result of low oil pressure over some appreciable time.
I think I may just replace with following:
http://www.summitracing.com/parts/CLE-SH875S
Any other suggestions are welcome. Lining up the galley holes goes without saying. I've been quite meticulous with this whole thing, minus the nicks due to cam removal.....
Thanks for the eyes and input and welcome more.
ps. forgot this good article about mopar oiling system.
http://www.moparmagazine.com/2011/ju...ne_oiling.html
I used to always coat cam and cam bearings (as well as crank) with STP on installation so they are not dry on first crank. I would also recomment mic'ing the bearing ID and cam OD before installation to make sure the fit is correct.
Gonna flex some muscles. Then I'll just have him remove and install them. Big recommendation was to also check the main bearings b/c of this condition.
Note that embarking on this cam change I was prepared for show stoppers. This definitely is one. I am partially pissed off, but also relieved. Relieved that it was caught prior to the galling making a formal introduction to my life.
I wonder if there is enough room to swap the bearings now or should I yank the engine out. I have access to a hoist and stand.
ps. even with the family. went in for our first ultrasound expecting a singleton...nope, twins!!
Pretty sure the block doesn't NEED to be removed, but machine shop will tell you that because it's a whipping to do in the truck.
For the front bearing, you must pull it as you need to pound it out from the back, but not if you were just doing #4.
+1...... And the extra clearance of the BL can only help. No way that motor needs to come out.
