Top cigarette lighter works but the bottom one doesn't
Old Jan 10, 2012 | 08:02 PM
Originally Posted by rumble_truck
same, accept I cant just reach my hand through my dashboard and around my radio.
Find a younger girl to do it for you. I have used that tactic before on a couple occasions.
Old Jan 10, 2012 | 08:16 PM
BackwoodsRam's Avatar
BackwoodsRam
the reach around always works
Old Jan 10, 2012 | 08:46 PM
gdstock's Avatar
gdstock
See...I was trying to behave and not put HeyYou on the spot....like asking what the younger girl should be wearing, where he would suggest standing.......
Old Jan 10, 2012 | 08:53 PM
chadhager03's Avatar
chadhager03
Anyways, found out the fuse in the box just wasn't there, replaced it and it works good, except it is always on
what's a good ignition source to be using because I want to hard wire (with a fuse) my radar detector for a cleaner dashboard. Thanks! I used my remote on my amp for my transmission temperature gauge but I don't want to keep using that because sometimes I don't use my stereo and I want to always know if there's a cop nearby.
Old Jan 10, 2012 | 08:54 PM
Mutt Bryant's Avatar
Mutt Bryant
mine had a broken wire somwhere in the harness so i pulled the outlet and used the hole to mount a push button ignition
thats awesome. How'd you manage that one?
Old Jan 10, 2012 | 09:21 PM
gdstock's Avatar
gdstock
There is an "add a fuse" that you can get. It has one wire hanging out to connect to and plugs into switched fuse slot. http://www.ebay.com/itm/DURITE-CIRCU...item45fda26b49
I think I am going to buy a couple. I keep forgetting. These are handy and make for a cleaner installation than cutting and splicing into other circuits.
Old Oct 22, 2012 | 10:34 AM
Demontreville's Avatar
Demontreville
How do replace the cigarette lighter in a 1996 Dodge Ram truck? When you remove the ash tray right next to it, it's too small to get your hand in there to take the nut off. I'm assuming that's how it is held in there? Also, is there an inline fuse on this? The one in the panel is not blown.
When you removed the faceplate, were you able to get your hand in there to access the lighter socket? I can't see how taking them two screws out gives you more room to access that? looks like them two screws just holds the bracket for the ash tray???
Old Oct 22, 2012 | 10:58 AM
UnregisteredUser's Avatar
UnregisteredUser
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Oct 22, 2012 | 12:12 PM
Demontreville
Thank you for the link to the manual, sounds like I can remove the cup holder and ash tray to pop off that part of the dash. I'll give it a whirl.
Old Oct 22, 2012 | 12:18 PM
Sooper's Avatar
Sooper
Originally Posted by UnregisteredUser
The power outlet fuse is in the PDC, the cigarette lighter fuse is in the interior fuse box.
PDC? Mind expanding on that please?
