Piece broken off differential gear
Old Jan 12, 2012 | 11:03 PM
mstephen89's Avatar
mstephen89
yea you would have to turn the drive shaft 4.1 times to turn the tire once. 3.55 turns to one tire turn would be 3.55's
Old Jan 12, 2012 | 11:09 PM
sam_priem's Avatar
sam_priem
thats it. i was close.
Old Jan 12, 2012 | 11:36 PM
iacordero's Avatar
iacordero
Originally Posted by dhvaughan
you might could pick up a side gear at the junkyard for next to nothing.
its probably been that way for a long time, and its probably not the end of the world, but its likely contributing to your noise. the 9-1/4 rear end is in every ram, ram van, durango, and dakota for like the last 100 years.
good question from merc - if not LSD then its really easy to change out.
No LSD on this one. I probably will end up changing that damaged gear as well as re-gearing if needed, but I'd rather hold off if it's not that big of a deal because there's a whole laundry list of stuff I need to do on the truck (ie. Shocks, tires, tranny flush, ball joints, tie rod, etc.). So if you guys don't think that the small broken piece is gonig to cause the whole thing to fall apart in the next 5k or 7k miles, 'just rather hold off and take care of it if and when I decide to re-gear.
Old Jan 13, 2012 | 07:55 AM
DoubleL24's Avatar
DoubleL24
Don't do a tranny flush on these transmissions, I've read a lot that people say it does more harm than good. I'm sure someone else will chime in on that or do some searching.
Old Jan 13, 2012 | 09:17 AM
Hahns5.2's Avatar
Hahns5.2
If you still have the cover off, the number of ring gear and pinion gear teeth or the gear ratio itself is usually stamped into the ring gear. Ring gear teeth divided by pinion teeth equals gear ratio.
Old Jan 13, 2012 | 10:04 AM
8uzzsaw's Avatar
8uzzsaw
Ive been told by several people not to flush these trans. Better to drop the pan and ajust the bands, clean up the govenor pressure sensor solenoid thingy and do new fluid and filter. Sound about right?
Old Jan 13, 2012 | 06:03 PM
iacordero's Avatar
iacordero
Okay, I dropped the pan and cleaned everything out. I adjusted the bands. The rear (inside trans) required very little adjustment. The front band (outside trans), which apparently needs to be thightened to 72 in/lb took almost 3 full turns to get to 72 in/lb. Now the head of the adjusting screw is almost flush with the edge of the locking nut. Does that seem even remotely normal? I don't want to overtighten and ruin the trans. The truck did have a tendency to slip in the lower gears pretty regularly before I did the work. I don't know if it has ever been adjusted, and it does have 180k miles, but it seemed like a lot of tightening to get it to the right torque. I don't really want to drive it with this doubt in my mind.
Old Jan 13, 2012 | 06:39 PM
Yeah, the band friction material wears off, so, tolerances open up. Also, it isn't really a direct relationship with how far the bolt moves, and how far the band moves...... you are attempting to reduce the circumference of a circle.
So long as you back it out the right amount, everything should be golden.
Old Jan 13, 2012 | 09:14 PM
gdstock's Avatar
gdstock
My manual is in the garage - so just shooting form the hip here - but I think after you tighten front band to 72 in lbs, you back of 2 7/8 turns.
I have not noticed any rear end noise (but I do not have good hearing). While I had rear drums off I spun axle and rear end sounds dry. Got gasket and will pull cover off tomorrow. Hope there aren't any loose pieces there!
Old Jan 13, 2012 | 09:55 PM
iacordero's Avatar
iacordero
I'll take a second look tomorrow morning when it's not so dark and cold out. I'll also drop the pan again since I haven't filled it yet an make sure I did the rear band correctly.
Can someone explain to me the purpose of backing out the screw after tightening? Is it similar to a brake drum and shoes in that you need to leave room for things to turn freely?
