Old Aug 17, 2015, 12:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
New battery new starter- wont start
Old Jan 15, 2012 | 01:03 AM
peshewa's Avatar
peshewa
Do not forget to check the FUSES - most overlooked thing with starting issues. I say find out what is wrong before dumping money for parts when you are guessing. if you hold a volt meter on the battery terminals while it is being cranked over, it should be above 10 volts, below that indicates something needs attention. I have read that the control unit is also responsible for voltage regulation, so that is a possibility. If new cables are in order, you can make your own. I use double insulated super flexible welder ground wire meant for welding machines available by the foot from farm & fleet type stores. That allows me to use a larger gauge & have better connections also. Don;t let the frustration force you into a corner, take a moment of zen for yourself & go about it calmly then you will find the answer faster. Good luck!
Old Jan 15, 2012 | 12:52 PM
sk187's Avatar
sk187
Originally Posted by sam_priem
no kidding
The cables are easy to remove from the starter and then a few clips holding the to the frame.
Any local battery or starter shop would make you new cables I dont think there is anything special about these.
You can get new ends at auto zone for the battery side just cut the old ends off, strip the wires and tighten them up.
Old Jan 15, 2012 | 01:16 PM
ministock6's Avatar
ministock6
check the neg ground on the engine block, We had one that had bad connection where ground bolts onto block, looked good but wasnt'
Old Jan 15, 2012 | 02:37 PM
lastrights's Avatar
lastrights
I remeber I used to blow my starter relay fuse all the time . Check that
Old Jan 15, 2012 | 06:35 PM
GTXpress's Avatar
GTXpress
Keep shotgunning parts at it. Eventually you will fix it.
Old Jan 15, 2012 | 06:52 PM
peshewa's Avatar
peshewa
GTXXpress, I hope that was a joke - otherwise it was dumber than a dumb thing.
Old Jan 17, 2012 | 08:10 PM
BIG_DARTHA's Avatar
BIG_DARTHA
Hey thanks yal helped alot! Turns out it was the starter relay, I felt like such an idiot! Just glad I got it fixed!
Old Jan 17, 2012 | 08:57 PM
lastrights's Avatar
lastrights
Yeah buddy !
Old Jan 17, 2012 | 10:40 PM
crazzywolfie's Avatar
crazzywolfie
with the symptoms you were describing i would have never thought it was the relay since it would start when you boosted it.
Old Jan 17, 2012 | 10:46 PM
Maybe the additional voltage would help the relay trip.....
