locker time..
Old Jan 14, 2012 | 08:48 PM
Originally Posted by offroadjosh
Will have to find out if i can do that. Might go ahead and do that. If i have that or pull the carrier ill rebuild and keep searching for a set of 60s cheapish. (soooo wish i had not sold the axles outta the wrecked 2500 i had!! Had lockers and 410s...
Slap yourself for me......
I would kill for a set of those. I have the 60s, but, 3.55s......
Old Jan 14, 2012 | 09:22 PM
offroadjosh's Avatar
offroadjosh
Cannnot believe i let them go!!! Next time.... lol
Old Jan 15, 2012 | 12:44 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
This is something you keep to yourself....
Old Jan 15, 2012 | 12:55 AM
merc225hp's Avatar
merc225hp
I think Firedodge bought that 4:56 gear set and locker and if I remember right he already had a locker of some type. You might see what he is up to for lockers. If all you are doing is changing the carrier it's not that hard to set it back up because you are leaving the pinion were it is. Couple of hrs work should get it done.
Old Jan 15, 2012 | 01:45 AM
redheadhunter21's Avatar
redheadhunter21
They have a loc-rite for the LSD differential, just letting you know
Old Jan 15, 2012 | 02:32 AM
mj23polaris's Avatar
mj23polaris
yukon grizzly locker, knock off detroit is wat i guess it is my .02
or a spool!?!?!?!?!
Old Jan 15, 2012 | 08:28 AM
or a spool!?!?!?!?!
Spool is a bad plan for a street driven daily driver.......
Old Jan 15, 2012 | 10:49 AM
offroadjosh
I rather have a spool than a locker.. I KNOW how a spool is going to react on ice and snow, a locker can on lokc and lock on you causing you to slide around worse lol. I will look around though..
Old Jan 15, 2012 | 11:22 AM
offroadjosh
..I do have a welder... :P Hmmm, could weld up the rear for now. Im half tempted to build the axles that are in it and go buy a diesel 3rd gen, and keep this 2nd gen for play only..(cannot afford to beat the hell outta my DD.)
Old Jan 15, 2012 | 11:25 AM
stewie01's Avatar
stewie01
Now we talkin!
