cheaper plenum plate
Old Jan 30, 2012 | 10:47 AM
  #41
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by jpryorx2
ok stupid question here but how are you guys torqueing down your plates? i have 3 of the clicker style torque wrenches. my 1/4 in one goes up to 50 inch pounds which is fine for the first round of torqueing then my 3/8 starts at 120 inch pounds and my 1/2 in starts at 30 ft pounds. so how do i get to 84 inch pounds? it converts to 7 ft pounds but i haven't been able to even find anyone that has one to go that low. how accurate does it really have to be? i do have an old beam style with the pointer needle but didn't know if that would be concidered close enough because it only has the lines at 5ft pounds and 10 pounds so i'd be guessing to get them to 7. any advice?
thanks
jason
1. Get the right torque wrench.
2. Follow the directions on install.
To convert foot pounds to inch pounds, multiply by 12.
To convert inch pounds to foot pounds, divide by 12.
3. Don't eff it up.
Originally Posted by roger_groom
Ok so question. I have an 01 1500 5.9 4wd. It is giving me issues and kind of lost. What are the signs of a blown plenum. My vacuum is strong and runs great until warm then starts acting like it is missing. This only happens when it hits high gears. Plugs are new as cap and rotor. Brings code for evaporation cannister. I use my truck daily so tearing it down without knowing is not what I want to do.
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Jan 30, 2012 | 11:04 AM
  #42
Johnny2Bad's Avatar
Johnny2Bad
Originally Posted by dodgeboy1979
i am curious about the canadian vs american assembly lines as i have two 5.9l rams with approx 160k miles on them and no plenum issues so to speak of.
not sure there were Canada plant versions of the truck. Easy way to find out would be if members check VIN ... If someone has a truck with VIN 1st digit of 2 it was made in Canada. My Canadian-market 96 1500 has 3 (Mexico). 1 or possibly 4 would be USA.
Chrysler does make a lot of vehicles in Canada ( a bigger % of production than GM and way bigger than Ford) but each plant only makes one platform. AFAIK its only Minivans and unibody cars (300, Charger, Challenger, used to be LX, Concorde , etc). I dont think they've made a body-on-frame vehicle in Ontario for a very long time.
Old Jan 30, 2012 | 12:06 PM
  #43
Augiedoggy's Avatar
Augiedoggy
its likely always there like mine but its only noticable in higher gears when the torque converter locks up and then the truck shudders... could be lots of things...Id check all your plugs to find the odd one and go from there...
Old Jan 30, 2012 | 12:15 PM
  #44
Augiedoggy's Avatar
Augiedoggy
[quote=Wh1t3NuKle;2706747]1. Get the right torque wrench.
3. Don't eff it up.
quote]
Comon man, You havent said anything here the OP hasnt already posted himself ? He's looking for suggestions on where to find the proper torgue wrench to do it right not a scolding
here's a link to a wrench I have which is the same manufacturer as the bigger ones at autozone or andvance auto sold under diffent names... mine works fine.
http://www.harborfreight.com/1-4-qua...ench-2696.html
if you have a local harbor freight you can just pick it up locally...they are on sale for under $20 all the time...
Old Jan 30, 2012 | 08:20 PM
  #45
roger_groom's Avatar
roger_groom
It may be. I have replaced all of the plugs about three weeks ago. And the cap and rotor.
I guess I should change the wires but I have checked the wires in the dark but they didn't light up.
Old Jan 30, 2012 | 09:09 PM
  #46
Route the wires per the TSB you can find in the faq section.
Old Jan 31, 2012 | 12:06 AM
  #47
jpryorx2's Avatar
jpryorx2
well got it mostly back together just need to change my oil and t stat. i ended up barrowing an old school snap on torque wrench that went down to 5 ft pounds. it was a royal pain thou because it was the type with a dial on top and seeing the needle on the back bolts wasn't easy. i plan to finish it up in the morning and see how it runs now. next on the list is figureing out the trans issues and doing some body work. all of which it's needed since i got the truck but just didn't have the time or the money or at least not at the same time.
Old Jan 31, 2012 | 08:51 AM
  #48
Augiedoggy's Avatar
Augiedoggy
I hear that... The GF wants a jeep now... My hands are full with the dodge
Old Jan 31, 2012 | 06:00 PM
  #49
roger_groom
Disconnect the front O2 sensor, and drive the truck that way for a while, see if it is any better.
So I have unplug the O2 sensor. Be driving it shortly. If it solves the problem what does that mean?
Old Jan 31, 2012 | 06:34 PM
  #50
Means you need to replace the front O2 sensor.
