Stripped Oil Filter Adaptor - My Ram is down
Old Jan 21, 2012 | 09:19 PM
thethrillofspeed's Avatar
thethrillofspeed
Default Stripped Oil Filter Adaptor - My Ram is down
Big storm coming in, decided to change the oil and filter because my 01 Ram is going to get a workout hauling me up to the mountains. I've used Napa Gold oil filters and have to get them really tight or they leak. Today putting the new filter on it felt funny. Pulled it off and the threads were messed up. Went and bought a Bosch filter so I didn't have to tighten it so tight, felt OK. Started the truck, zero oil pressure. Shut it off and my drain bucket was full. So I'm pretty sure I stripped the oil filter adaptor...the tube the oil filter screws on to. How in the world do you remove that? What's the official name for that part...I asked the rocket scientists at Autozone and they only could find oil filters.
Old Jan 21, 2012 | 10:11 PM
gdstock's Avatar
gdstock
Go to the FAQ/DIY section and download the factory service manual. I have not looked on a Ram, but I have never seen a filter adapter that would not unbolt and take out.
There is a parts manual ther also. You can look at parts list and give AZ a Dodge part number to cross referenece. AZ ,most likely willn ot have in stock, but neither will anyone else.
This is from parts manual. Oil filter plate is #53021053 but is on nest page.
Old Jan 21, 2012 | 10:30 PM
offroadjosh's Avatar
offroadjosh
Are you sure its stripped and not double gasket-ed?
Old Jan 21, 2012 | 11:01 PM
thethrillofspeed
There is the part number, a huge thank you!! I'm downloading the service manual so I can figure out how that puppy comes out.
Definitely not double gasketed, I triple checked that.
Thanks guys!
Old Jan 21, 2012 | 11:33 PM
gdstock's Avatar
gdstock
I think it is probably a 1/2" pipe nipple if I recall. If you can pull it out (unscrew it) and compare it to a pipe fitting...
Also make sure the adapter plate (part number referenced in test in previous post) isnot loose and allow oil to leak above it.
Old Jan 22, 2012 | 07:15 AM
Novarider's Avatar
Novarider
Can you see the threads to confirm they are stripped? Or at least feel them to confirm? I wouldn't pull that off unless I was sure. Shouldn't the filter be made of softer metal than the threads so that doesn't happen?
Old Jan 22, 2012 | 10:30 AM
offroadjosh
I would think so
Old Jan 22, 2012 | 11:34 AM
thethrillofspeed
I've tried three different oil filters, pretty sure I screwed up the threads on the oil filter connector. Looks like the connector just unbolts and is only like $6. Now the trick is to find one on a Sunday.
Old Feb 1, 2012 | 12:12 AM
thethrillofspeed
My Ram is back in action! I did mess up the threads on the oil filter connector. Good news is it is a $7 part and easy to replace. A 1" deep socket and it came right off. Thanks for the help.
