tire psi?
Old Jan 22, 2012 | 04:48 PM
merc225hp's Avatar
merc225hp
Originally Posted by Xtremjeepn
You obviously have never felt a tire thus way. Tells you the exact same information the chaulk does. Try it.
A perfectly inflated tire will have the same temp all the way across it.
The quote button realy helps so we can tell who you are talking to.
Old Jan 22, 2012 | 04:50 PM
Xtremjeepn's Avatar
Xtremjeepn
I'm sorry you have lost so much sensitivity in your hands. Keep using chaulk.
For those with normal use if their hands it's a very noticeable difference.
Old Jan 22, 2012 | 04:51 PM
Xtremjeepn's Avatar
Xtremjeepn
Sorry. Missed it posting from the Mobile version of the site.
Old Jan 22, 2012 | 07:59 PM
charlie1935's Avatar
charlie1935
My hand is not that sensitive. I usually used an IR thermometer. That works great.
I have been doing this a long time.
I agree.
Old Jan 22, 2012 | 09:10 PM
gdstock's Avatar
gdstock
Tires are required to have size, weight range, speed range, AND pressure on the sidewall.
Old Jan 22, 2012 | 09:22 PM
Yeah, but, no where does it say it has to be easily found, or, in a font large enough to read without a damn microscope.
Old Jan 22, 2012 | 11:00 PM
gdstock's Avatar
gdstock
Or rubbed off by driving against curbs!
Old Jan 22, 2012 | 11:05 PM
GTXpress's Avatar
GTXpress
I use a magical device called a tire pressure guage to check my pressures. Mine is chrome
Keep looking. Its on there somewhere, has to be.
Old Jan 22, 2012 | 11:45 PM
merc225hp's Avatar
merc225hp
Have a look on the other side of the tire. If it has been curbed/rubbed off the one side the other side might still have it.
