hard cold start & surges/ bucks while trying maintain speed
#31
#32
#33
#34
#35
#36
#37
tps. results.. key on engine off no throttle.. black to org/dk blue = .720 WOT 3.877 volts. volts climb smooth from idle to WOT no jumps or loss of voltage. max adj to 0.738 volts on idle. is there any other sensors i could test with this multimeter while i am barrowing my fathers. i used a fluke 16 multimeter. it is digital.
#38
You guys realize that with some age also comes some wisdom. Don't jump to "conclusions" Testing this, testing that and ruling out the obvious cause "it can't be that simple!" I'm telling ya, If your computer doesn't have GOOD power, it will not run correctly. The computer gets "confused". Does it sometimes feel like your getting rear ended? Start to sputter like there's not a good spark? Slow, sluggish? How do you think it would run if the power for the comp is on, then off, then on (but less than the required 14 volts)? Humor me, check out those wires. Check resistance to ground while moving the wires around, etc. Check the main power @ the computer etc.
#40
