truck jumps out of 2hi and just grinds
Old Jan 22, 2012 | 10:27 PM
dlyter09's Avatar
dlyter09
I paid 500 for my transfer case and it had a 90hard day warranty... just call around to some local salvage yards to find what ya need
Old Jan 23, 2012 | 08:11 AM
chadhager03's Avatar
chadhager03
I wouldn't worry about it being bone dry either, when I bought my truck mine was bone dry as well and I've had no problems for over a year
Old Jan 23, 2012 | 07:09 PM
brandon19's Avatar
brandon19
hey man i pulled my tail shaft housing off and there was a ring but it wasnt bent broke or damanged! so i took further action and took the transfercase out of my truck pulled it apart and there was all kinds of shavings so i took all the gears out to check the teeth and everything was good except the range fork! its all wore and the shavings came from it! i was wondering would i be able to reuse the gear the rang fork holds and where could i get a range fork??
Old Jan 23, 2012 | 07:51 PM
Transfer case parts.
Replace the fork, AND the gear. You don't wanna have to do this twice. Make sure you get the cute little feet that go on the fork. They ride in the grove in the gear, to prevent metal to metal contact.
Old Jan 23, 2012 | 10:04 PM
brandon19's Avatar
brandon19
ok but my question is where can i get the range fork at?i cant get it from a autozone or nething they dont carry it! so where ca i get it from and what is the gear called?
Old Jan 23, 2012 | 10:08 PM
brandon19's Avatar
brandon19
the gear is fine the teeth arent worn chipped ornething!the local machanic said i could reuse it cause there is no damage to it just the range fork is all worn and chipped!
Old Jan 23, 2012 | 10:19 PM
Here ya go.
Old Jan 23, 2012 | 10:37 PM
brandon19's Avatar
brandon19
thanks for the help man!
Old Jan 24, 2012 | 03:04 AM
JJones31682's Avatar
JJones31682
I was going to say the same, you need a range fork and possibly a range hub. My TC ran dry, ate up the teflon pads, then ate all the way through the fork. Then it decided to shift into neutral on the highway, fun times. I managed to work it into 4lo andmade the 5 mile trip home at 4000 rpm, hoping the truck would just blow up already. I picked up a fork for $68 at a tranny supplier. It was easy to install, just watch carefully how your TC comes apart and put it back together in reverse order.
Old Feb 20, 2012 | 12:28 PM
brandon19's Avatar
brandon19
Default just put my transfercase back together and still has a grind to it in 2hi
ok i just had to replace my range fork and hub in my transfercase and put it back together put it in my truck and in 2hi when im in drive it still has a type of wine or grind in it what could it be?i need help asap i need my truck its my only way of transpertation!
