truck jumps out of 2hi and just grinds
Old Jan 22, 2012 | 07:54 PM
brandon19's Avatar
brandon19
Default truck jumps out of 2hi and just grinds
hey my names brandon i have a 98 dodge ram 1500 4x4 and when im driving it jumps out of 2hi in to nuetral and all it does is grind! has been doing that for about a week and has gotton worse!!now when i crank my truck it can be in 2hi but when give it gas it doesnt move just jumps out but will go in 4hi and moves foward and reverse and it moves in 4lo i need help with this a.s.a.p due 2 me having 3 kids in carseats and it being my onli way of transpertation back and forth to the doctors
Old Jan 22, 2012 | 08:07 PM
Drop the rear driveshaft, pull the tailshaft housing off the t-case, check and see if the snap ring on the output shaft is still there....
Old Jan 22, 2012 | 08:50 PM
brandon19's Avatar
brandon19
ok ill do this tomarrow! but i pulled my plug on my transfercase to check my fluid and it was bone dry! i pulled both plugs and no fluid came out i ran my pinky finger in the whole and got alittle bit of fluid it was black and had a slight burrnt smell to it but i couldnt feel any shavings! i flushed it by putting fluid through it and it didnt get any shavings so i guess thats good? if that snap ring isnt there any idea of how much it would cost?
Old Jan 22, 2012 | 08:58 PM
Bout 50 bucks from these guys. Quad 4x4 seems to be sold out...... This is a better part than the snap ring it replaces. It simply will NOT come off....
Old Jan 22, 2012 | 09:04 PM
brandon19's Avatar
brandon19
ok man thanks ill post up tomarrow on how that works out! but 1 more question! every once and awhile while im driving mytruck spits and sputters when i accelerate like its out of gas but it has between 1/4 n 1/2 a tank i pulled my plugs and cleaned them and i dropped my tank and cleaned it my fuel pump was replaced and filter was good and it still does it! like it has water or somethng in the gas do you know what it could be?
Old Jan 22, 2012 | 09:06 PM
Check the stickied plenum thread at the top of this forum...... if that part hasn't been addressed, that's where you are going to need to start.
Could be any number of things though...... best bet is to first make sure everything is up to snuff maintenance-wise. Plenum fixed, full tune-up, (cap/rotor/wires/plugs/pcv), and take it from there.
Old Jan 22, 2012 | 09:11 PM
brandon19's Avatar
brandon19
ok man i didnt think abut a tune up i havent done a tune up on it since ive got it the truck! i traded my ford for it and now im starting to regret it : ( all ive had is problems since ive got the truck! but thanks for the info ill try this tomarrow and see how it goes if nothing else how much would a new or used tc cost?
Old Jan 22, 2012 | 09:21 PM
anywhere from a couple hundred to over a thousand, depending on what you get, and where you get it. Rather location dependent too..... some places they are a dime a dozen, other places..... well..... better be feeling masochistic when you go to pay for it.
Welcome to DF!
Old Jan 22, 2012 | 09:32 PM
brandon19's Avatar
brandon19
ok well what year moduls are interchangeable with my 98 dodge?
Old Jan 22, 2012 | 10:23 PM
I think 98 all the way up to 01...... the 94-97 would probably fit in there, but, shift pattern is different. You just want a 231D (or 231DHD if you can find one...). I think they came in Ram's, Durango's, and Dakota's.
