Nv3500 and 360
Old Jan 25, 2012 | 10:17 PM
mccart's Avatar
mccart
Default Nv3500 and 360
Will the 360 bolt up to the nv3500. I didnt think there was any difference between the 318 and 360 but they never put a 360 in a half ton with the 3500 tranny. And would the 3500 hold up, its going to be a built 360 round about 450-475 hp
Old Jan 25, 2012 | 10:19 PM
BackwoodsRam's Avatar
BackwoodsRam
nv3500 wasn't designed to handle more than 300 hp
Old Jan 25, 2012 | 10:34 PM
Hahns5.2's Avatar
Hahns5.2
Ft/lbs, not hp.
Mine has been taking 440ish ft/lbs on boost for ~30,000 miles now.
Old Jan 26, 2012 | 02:02 AM
99dodge318's Avatar
99dodge318
The 360's only came with a standard transmission in the 3/4 trucks, and even then they got tge nv4500 not the nv3500
Old Jan 26, 2012 | 02:10 AM
BackwoodsRam
Yea but the clutch was the same size and the bolt pattern was the same size. Yes an nv3500 will bolt behind a 360. I was just letting the OP know that the 3500 wasn't designed to take the power he will be putting in front of it. He'd be better of with a nv4500
Old Jan 26, 2012 | 04:31 AM
Wombat Ranger's Avatar
Wombat Ranger
^^^ If he want's towing capability and HD truck-like strength. But the more car-like ratio gaps of a 3500 make it more comfortable to drive and more fun in a hot rod application.
Old Jan 26, 2012 | 04:33 AM
Wombat Ranger
Old Jan 26, 2012 | 08:29 AM
mccart's Avatar
mccart
Well im going to see what happens with the 3500 it needs a clutch too so i think im going to get the centerforce dual friction, i have heard nothing but good about them
Old Jan 26, 2012 | 12:28 PM
Hahns5.2's Avatar
Hahns5.2
Disagree. The NV3500 isn't car-like at all. The NV4500 is actually better ratio-wise, besides the granny 1st which you wont use unloaded on the street anyways. Neither are meant to have the gears slammed though.
Old Aug 31, 2022 | 04:55 PM
Hillbilly5959's Avatar
Hillbilly5959
would a nv3500 from a 5.9 bolt to a 4.7 , im asking bc i have a 4.7 but due to a leak my nv 3500 is toast and i need a donar trans
