Front Brakes Cookin' (Help)
Old Jan 29, 2012 | 03:30 PM
gdstock's Avatar
gdstock
Originally Posted by Crackshot
Could be a proportioning valve too?
That sounds plausible. Never had one fail, but wouldn't that throw a brake light as well as cause a brake to drag?
Old Jan 29, 2012 | 04:26 PM
Hylander7's Avatar
Hylander7
I have no brake drag.
I think I will buy new quality Pads and go from there
Should I go Semi-Metallic or Ceramic ?
Old Jan 29, 2012 | 04:48 PM
MoparMan1991's Avatar
MoparMan1991
Honestly get anything other than the cheap crap. At Oreiley I usually get the mid grade of everything.
Old Jan 31, 2012 | 01:14 PM
Hylander7's Avatar
Hylander7
Update again;
Installed new quality Wagner semi-metalic pads.
Took for test drive, acted fine but the brake and anti-lock lights came on breifly and went off. Just got back from another test drive, lights camre on again and stayed on, perked truck turned off key for about 10 seconds and restarted it, lights went off and so far still off.
I don't really know much about the anti-lock brake system, so what and how do I diagnose the issue ?
Old Jan 31, 2012 | 01:20 PM
2 or 4 wheel ABS? (check and see if you have front wheel speed sensors.)
Old Jan 31, 2012 | 03:46 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Access to a scanner to help out? I don't remember how far apart we are....but I've got one.
Rear ABS is tied into the toner ring of the rear diff right?
Old Jan 31, 2012 | 03:55 PM
Hylander7's Avatar
Hylander7
Just got back from from another test drive down the canyon, they got Smokin' hot again
Old Jan 31, 2012 | 04:08 PM
Try downshifting instead of riding the brake...... yes, you can do that with an auto too...
Old Jan 31, 2012 | 04:32 PM
Hylander7's Avatar
Hylander7
I could do that, but there there is still an issue, with the grade I'm going down the brakes should not be getting that hot on any vehicle.
Old Jan 31, 2012 | 05:30 PM
You ever get your rotors measured for thickness?
What size tires ya runnin'?
Back brakes working right?
