CHanged Plenum ....Not fixed
Old Mar 13, 2012 | 09:05 AM
  #61
aim4squirrels's Avatar
aim4squirrels
Not going to bother to read that whole mess. Plenum fixed and still misfire on 5.
1. Plug wires to 7 and five touching or arching. Route them far away from each other, snake number 5 over the valve cover under the PCV.
2. PCV valve bad. If you just have to know if oil is coming from this spot, make a catch can out of some tubing and an air compressor separator and find out.
3. Excessive oil consumption gas led to carbon buildup on valves. 2 cans of Mopar combustion chamber cleaner. Drive for a half hour, park truck, remove air cleaner assembly start truck, spray MCCC thru Tb blades, finish can, kill engine, soak for 2 hours.
Restart truck, let it idle enough to get into closed loop, romp on pedal a couple of times to check for smoke before you take it on the street, hit the streets and do 5 WOT runs for a minimum of 9 seconds.
Repeat process with second can.
4. Loose #5 injector connection.
5. Dirty #5 injector, try techron concentrate+ on a 1/4 tank, out pull injector and clean in sonic jewelry cleaner with the techron.
6. Head crack at the valve seat, replace head.
7. Valve seals gone, replace.
8. Valve seat damaged, verify with leak down test.
9. Rings gone, rebuild time.
Old Mar 13, 2012 | 09:21 AM
  #62
mantisman51's Avatar
mantisman51
He replaced the engine.
Old Mar 13, 2012 | 10:09 AM
  #63
aim4squirrels
Sweet, easy fix!
Old Mar 13, 2012 | 11:20 AM
  #64
A_POLVADO's Avatar
A_POLVADO
Originally Posted by Augiedoggy
here are the 4 hole upgrade ones...
http://www.ebay.com/itm/1999-Dodge-R...item27c3278180
These are remanufactured oem ones...dont need fuel sinc done
http://www.ebay.com/itm/New-Siemens-...item460063f345
and these are what I got... the newest generation 3 ones...( got mine from the seller in the first link but I messaged him asking for them (cost me $180 )
http://www.ebay.com/itm/8-TRE-Fuel-I...item4161385679
any mechanic with the right equipment can re sinc your fuel timing in about 15 minutes...
Not to beat a dead horse but will these work on a 2001 it says 99 model just wandering if they do im fixing to order them....
