No Overdrive
Old Jan 31, 2012 | 02:33 PM
jnellydodge's Avatar
jnellydodge
Default No Overdrive
The Truck: 1993 Dodge W150 5.9 V8 4x4 w/A518
The O/D has never worked since ive owned this truck. Everything else does. I just replaced the motor and while it was out i noticed that the TC had been replaced and was dated From November 2003. Well the new motor is in and running great now i would like to address the O/D issue so here we go:
The issue: 3-4 upshift is not taking place. All other shift patterns are normal, it just will not shift into O/D
Trans was rebuilt in 2003, unsure of mileage on the rebuilt trans
Have checked:
FLUIDS - Proper level and nice clean red color
CODES - there are none (besides 12 and 55 which are normal). During motor replacement the computer threw a code for a faulty TPS which fixed some idle issues i was having but unfortunatly didnt help the o/d issue
FUSES - good
*O/D on-off switch illuminates but doesnt change anything when on or off
*Cruise control works
*Speedometer works so this would rule out the speed sensor correct? again no fault codes
*Temp gauge works so this would rule out the coolant sensor correct? I understand the SMEC may not see if it the temp sensor failed below 65* but the temp gauge works...
*OD selnoid-no code for malfunction (and i would believe rarely fail)
Any ideas?
Old Jan 31, 2012 | 02:35 PM
Looks like maybe the trans was changed/rebuilt a few years back. Best guess would be wrong O/D/TCC solenoid set.
Old Jan 31, 2012 | 04:40 PM
jnellydodge
Is the 3 pin connector (w 3 wires going to it) located in the trans case above the rear drivers side of the trans pan the connector for the solenoids?
Old Jan 31, 2012 | 05:27 PM
Think so.... you don't have the electronic governor... so, yeah, that sounds right.
Old Jan 31, 2012 | 05:47 PM
xjarhead69's Avatar
xjarhead69
You can download the 95 service manual from the FAQ's section here https://dodgeforum.com/forum/2nd-gen...e-manuals.html, same trans you have.
Also you can checkout the video's for the trans rebuild here http://s809.photobucket.com/albums/z...ATSG%20Videos/.
Dave
