2-3" more of lift possible?
Old Feb 1, 2012 | 03:48 AM
ryan0714's Avatar
ryan0714
Default 2-3" more of lift possible?
so i have a 3" body lift right now, but im kinda wanting an extra 2-3" more. if i buy new 2-3" lift coil springs and add-a-leaf in the back. will it fit without having to buy or do anything else for that matter? will the control arms and everything reach? I dont care if i gotta get new control arms, i like the look of aftermarket ones anyway. Just lookin for someone to tell me what all id need to have or do in order to get that added little bit. Im gonna be puttin 35s on as well. i know they will clear with the body lift, but i still want a couple more inches.
Old Feb 1, 2012 | 04:35 AM
chelios1368's Avatar
chelios1368
To bring your front up you can use coils from a 2500. That's what I did with a 2.5" leveling kit with no problems. As far as the rear end add a leafs should go in with no problem.
Old Feb 1, 2012 | 04:37 AM
ryan0714's Avatar
ryan0714
thing i need to know is, when i put the longer coils in, do i need the longer control arms or no?
Old Feb 1, 2012 | 05:03 AM
chelios1368
To my knowledge no. I have stock control arms in mine and have no issue
Old Feb 1, 2012 | 05:28 AM
ryan0714's Avatar
ryan0714
alright man thanks alot. ill post pics in about 2 weeks or a month when i buy the coils and stuff and lift it little more. ill have 6" total lift then. will prob look dumb with 33s...until i get the 35s
Old Feb 1, 2012 | 06:37 AM
kejobe's Avatar
kejobe
IIRC, you can go up to 3" suspension lift without having to do control arms or pitman arm. After 3" everything WILL be needed.
Old Feb 1, 2012 | 07:06 AM
Augiedoggy's Avatar
Augiedoggy
for the rear thry make a shackle reversal bracket to lift as well that would be less harsh than an add a leaf... Im in the same situaton as you and want to go 2.5" or so higher with a body lift.
Old Feb 1, 2012 | 10:20 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Your only issue will be backspacing of your wheels.
Scenario: stock control arms, +3" SL lift, 35" tires assuming 12.5" wide, axle pulls backward and contact will occur on control arms and/or inner fender. I will say you'll be ok, but will rub. To what extent, I'm not sure. To improve your chances just a bit on the tire, go 315/75/16. It's slightly narrower.
My backspacing is 4.5" and its money for my setup. I posted a picture of my changes in What Did you do to your Ram today.
